Help H22a Engine Swap Emergency!!!
Old 11-12-2001, 02:35 AM
hungy's Avatar
I nees help guys!! I blew my 97 2.2 engine and I need a new one. So I am thinking about going with a H22A since I need to swap my engine. The thing is that I have a automatic so I was told by my friend that the H22A prelude engine will fit but that the ECU's are for manuels. Help please.... I just need an engine for my baby... Im only going with a H22A is bc I heard that it bolts in perfectly without any complications and I was thinking it is probably cheaper then the stock motors due to the higher demand thus higher supply. Please help.
thanks in advance
Old 11-12-2001, 03:20 AM
jacobzking's Avatar
just throw in a 5 speed tranny as well, not that hard to do.
Old 11-12-2001, 03:26 AM
hungy's Avatar
I need all the suggestions you guys can give me? Is it possible to do a H22A swap into a automatic without changing to manuel? I dont have that much money? Maybe only close to 2500 and I dont know how to do it myself. Which ECU's will I use?
thanks
bob
Old 11-12-2001, 03:52 AM
jacobzking's Avatar
the block should (90% sure) bolt up to your auto tranny and same ECU. you'd wanna use a 4spd auto tranny ecu from a prelude though, otherwise you're car won't run as well as it should. what city you in?
Old 11-12-2001, 09:36 AM
Turn Signals are good!
SumkidwithaCL's Avatar
The auto tranny will bolt up directly... that would be an interesting combination!! The ecu should always be changed when changing the engine... the prelude and cl use 2 different ecu's anyway... regardless of the tranny. But if you go with a 5-speed, your gonna need some clutch stuff, different brake pedal, axels from a 5-speed, i'm sure other stuff... but you'll get better gas mileage and it'll be faster than with the auto... but that does seem like a good idea... let us know what you decide... and give Ross (rmstoico) a shout for the engine!!
Old 11-12-2001, 10:50 AM
hungy's Avatar
Do you guys know what ECU goes with what engine.
And what is the OBD1 or OBD2 stuff. Can you guys explain?
thanks
Old 11-12-2001, 01:11 PM
jacobzking's Avatar
obd is on board diagnostics gen 1 or gen 2. i think gen 2 started in 97. gen 1 is better for racing because it is more modifiable and has wider perameters i believe.
Old 11-12-2001, 07:59 PM
IgotCLass
dioconcepts2.2cl's Avatar
The best way to go with the H22a is to swap to a manual and you need to swap the ecu. the manual is more enjoyable and you will have a lot of fun with the power.
suj
Old 11-12-2001, 08:27 PM
i like chicken
rmstoico's Avatar
we can get the obd 1 ecu modified with no rev limiter.
Old 11-12-2001, 09:29 PM
hungy's Avatar
How much for the ECU rmstoico
?? Which engine does that match up with the 94-96 prelude? Will that work with my automatic transmision from my CL?
thanks
Old 11-13-2001, 09:50 PM
IgotCLass
you also may want to check out www.okinawaimportmotorsports.com they carry any jdm motor with 40,000 or less miles. they also have package prices that include motor, tranny, ecu, and wiring harness. check them out, they are good friends of mine and they do quality work.
suj
rockyboy
08-04-2024 10:35 AM
dirtyspitshine
01-03-2023 08:23 PM
justin7779
12-25-2015 10:33 PM
02tljj
09-11-2015 12:37 PM
Quick Reply: Help H22a Engine Swap Emergency!!!
