HELP! Front End Clunk....Ball Joints?
Old Jun 25, 2010 | 01:35 PM
noobiecl's Avatar
I hear a bad clunk when going over bumps in my 99 2.3 cl. I can almost tell it is a joint seperating. Although, the clunk seems to go away while I am breaking. I have replaced the upper control arms and tie rod ends on both sides. It is strange that is goes away while breaking.
I have inspected the suspension to make sure everything is tight and also the braking system.
Anyone think it is my lower ball joints? Does that makes sense?
Old Jun 25, 2010 | 04:53 PM
fliplyricist1's Avatar
Staggered 1st Gen
damn, cant believe you posted this at the same time I did on another board. I have a similar issue except it only happens while accellerating, and goes away once I hit like 40mph. It's a hollow clunking sound, almost sounds like you're driving on a flat tire...
Old Jun 26, 2010 | 10:26 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
when it happened to me it was the rubber bushings disintegrating
Old Jun 28, 2010 | 02:48 PM
noobiecl's Avatar
Thanks for the idea. What bushings did find were the problem?
When this happened to you. Did your noise go away you were braking as your went over the bumps? Or did the noise happen at all times.
I can't seem to figure out why braking helps the noise.
Old Jun 28, 2010 | 03:00 PM
(Mid-Atlantic)
It was usually while braking, it would cause the shock tower to move forward
I have the write-up at home somewhere, but it was the upper shock tower bushings I believe
Old Jun 28, 2010 | 09:31 PM
noobiecl's Avatar
Thanks for the info!
Old Jun 29, 2010 | 12:19 PM
Myxomatosis's Avatar
my sway bar ends made the same noise.
Old Jul 1, 2010 | 04:02 PM
97'CL2.2's Avatar
have u had ur wheels off recently? i had this problem and it ended up being a loose rear wheel. i had the same clunking sound only it was in sync with the wheel speed. it turned out the lugs were tight but the rear rotor was canted a touch over the hub so when i put the wheel on and tightened everything down it still clunked but when i applied the brakes it held the rotor tightly to the hub and the noise stopped. just somthing to check out
Old Jul 1, 2010 | 11:22 PM
DaInFaMMuS1's Avatar
Same exact thing happened to me with my right front wheel. I was like damn wtf IS that?! Haha.
Old Jul 14, 2010 | 05:07 PM
MEM3's Avatar
I had the same noise and it ended up being my sway bar bushings (not the endlinks)
Old Jul 27, 2010 | 09:28 AM
noobiecl's Avatar
Replaced the sway bar bushings, ones toward the middle not then ends...noise went away!
Old Jul 27, 2010 | 09:36 AM
noobiecl's Avatar
Rear Suspension Noise - Sounds like something is loose
I have a noise in the rear suspension that sounds like a bushing is loose, especially when going over bumps or uneven road slowly. The noise is only over bumps.
I replaced the upper strut bushings a couple of years back along with the rear struts and upper control arms and that did not solve the problem. Now that it is a few years later I have decided to do something about the noise.
Could it be the rear sway bar bushings? They do look a bit dry and cracked.
The noise does go away when passengers are in the back seat. So it seems that downward pressure on the issue takes care of it.
Any thoughts?
Old Jul 27, 2010 | 12:09 PM
(Mid-Atlantic)
could definitely be the sway bar bushings, replace them with PU bushings
Old Jul 27, 2010 | 01:39 PM
Staggered 1st Gen
sorry for the n00bishness, but does anyone have a picture of exactly where 'said' sway bar bushing is located?
I jacked up the front of my car and inspected everything thoroughly and couldn't find anything odd except for the already known copious amounts of cv axle grease splattered everywhere...and one of my bushings was significantly loose (don't know how or why the nut got unseated that much). It's the bushing that has 2 seperate halves with a gap in the middle. I noticed that on both sides the lower bushings were starting to crack. I torqued it back down but the passenger front end is still making that clunking noise...and it seems to be getting progressively worse
Old Jul 27, 2010 | 01:53 PM
(Mid-Atlantic)
^ when I had my noise issue it was the bushings on the shock tower assembly, not the sway bar bushings
Old Jul 29, 2010 | 05:37 AM
Staggered 1st Gen
^^ damn never thought of that...I'll be sure to check it out thanks brutha...but now I'm kinda fearing this may be a wheel bearing issue as it only makes the noise while im accelerating and giving the car gas....otherwise nothing
TLDude876
Dec 28, 2016 03:18 PM
02tljj
Sep 11, 2015 12:37 PM
08 NBP TL
Sep 8, 2015 08:49 PM
