Help With Defroster!!
i already checked my fuses the other day, but i'll check again just to make sure....but could it also be broken because some of the wires on tha back window are messed up??
Stage 1 Audi S5
Does the defroster back window "spark" a little when on at night?
IF it does then it means that your lines on the back window have been cut thus breaking the circuit. There is a metal paint that can fix this probem.
It is called something like trace paing and is about $25 for a 4 oz bottle. You wouls use a tooth pick to apply the paint to the areas that "spark" and it will complete the circuit and fix the problem-if a broken ciruit on the back window is THE problem.
Hope this helps.
Hope this helps.
peter-CL-S
01-31-2002 08:10 PM
