Rear Defrost causes Static on Radio
Quick Question???
Does anyone else have static on the radio when using the rear defrost? Regardless of the station when the rear defrost is on the radio has static.
Is it just the radio or do cd's do it too? My guess would be a bad ground, but if your system is stock then it shouldn't be a problem. There could be a problem with your cable for the antenna (sp?) I don't know if they are shielded or not, but if the shield broke then it would be a lot more susceptible to interference from other things. The first thing you might check is to pull out the radio and make sure the connection to the cable is not loose. Hope this helps.
BoricuaTL
Apr 8, 2016 01:08 PM
handsom-hustla
Nov 13, 2015 05:04 PM
Sep 15, 2015 06:44 PM
sputik
Sep 7, 2015 01:40 PM
