help car doesnt start
Old Dec 20, 2004 | 01:18 PM
gucciCLgirl's Avatar
well my car doesnt start...i charged the battery and tried starting it and it still doenst work...when i try and turn on my car, nothing happens...my car doesnt make any sound at all...the radio works, the horn works....but my car doesnt want to start...people are telling me it was the battery or the connections...people also said it could be the starter or the alternator...well i dont know what it is...i dont know what to do...help
Old Dec 20, 2004 | 02:09 PM
Slooo97CL's Avatar
well you need someone to test out the battery and alternator, if those are ok, then its most likely your starter.
you have an aftermarket alarm on the car? installed some sort of kill switch?
Old Dec 20, 2004 | 02:31 PM
VXCL's Avatar
AWD Torque Monster
i would start with the basics. fuel, air, and spark. sometimes its just something stupid.
Old Dec 20, 2004 | 03:04 PM
Chiny-J's Avatar
it may be your starter. check to see if the wires from the battery are connected properly to your starter. also check if you have a good ground from the starter. if your ground looks as if its corroded, try cleaning it with a wire brush.
Old Dec 20, 2004 | 04:31 PM
hey thanks peps...sorry but i dont know much about things under the hood...typical girl...my friend is going to check it out...i hope someone can fix it soon...
Old Dec 20, 2004 | 04:53 PM
sumdumguy's Avatar
a jawful a somethin awful
If everything else works, I'm guessing it's your starter.
Old Dec 20, 2004 | 06:43 PM
baka_t's Avatar
The movement has started
Battery connection, battery cable to starter, main 100amp fuse, It could be so many things.
Old Dec 20, 2004 | 07:34 PM
fusionnv's Avatar
Gimmie my points Biatch!
Yup mine went couple of weeks ago. Everything work except being able to start the car. Sucks,
Old Dec 20, 2004 | 07:52 PM
so what was wrong with your car?
Old Dec 20, 2004 | 08:12 PM
bebop.fey's Avatar
ahnyoung!
it could prolly be the kill switch . . . or something around there within the starter
and i really don't think it's ure battery or somewhat. . just the wiring = /
Old Dec 20, 2004 | 08:23 PM
joeshmoe's Avatar
My Home Planet
Try putting it in neutral and starting it. Even jiggle the shift knob a little in Park while keeping the key turned.
Old Dec 20, 2004 | 08:51 PM
i did that...and it still didnt work...
Old Dec 21, 2004 | 11:05 AM
joeshmoe's Avatar
My Home Planet
hmmm
How about banging on the starter while someone turns the key. You can use a big wrench or something like that. It takes 2 people though because you have to hit the starter as you turn the key to start it.
Old Dec 21, 2004 | 11:22 AM
fusionnv's Avatar
hmmm
If she got a 4 cylinder like I do it kinda hard to do that. There is stuff on top of it. You have a very narrow space. Also whoever is banging on the thing to be careful not to miss or hit too hard. There is a chance that you can damage more than the starter if you do it this way. My starter was damaged so bad that it would start this way but generally this will get u to where you going and that is it.
Old Dec 21, 2004 | 11:39 AM
WayFastWhitey's Avatar
check fuses?
Old Dec 21, 2004 | 12:55 PM
legendaryCL98's Avatar
'07 November = STI
Originally Posted by WayFastWhitey
check fuses?
check your fuse.. i forgot which one though.. it prevents u from starting the car if its blown.. just pull them all out one by one and replace the ones that are blown..
Old Dec 21, 2004 | 01:23 PM
DivineCL's Avatar
Revelation 3:15-17
If you show us a pic pf yourself I can help you.
Old Dec 21, 2004 | 06:07 PM
joeshmoe's Avatar
My Home Planet
Banging on it is not a fix. It's just to verify that the starter is the problem. It can be done from underneath the car if it is too difficult to get to it from above.
Old Dec 21, 2004 | 08:09 PM
97Cl22's Avatar
Comrade Stalin
I'm going with starter on this one...if everything else works except the car starting...it seems like a pretty safe bet to be the starter.
Old Dec 21, 2004 | 11:25 PM
Chiny-J's Avatar
check your ignition switch fuse and your fuel pump fuse.
Old Dec 22, 2004 | 12:12 PM
check fuses...if those check out must be the starter, can you still lock/unlock the car with the remote?
Old Dec 22, 2004 | 09:34 PM
thanks peps for all your help...i found out what the problem was...and it was the starter...i hitted it and it started to work...so someone changed my starter for me today...so now im happy....thanks again people...
Old Dec 23, 2004 | 09:18 AM
cool, glad to hear its fixed
saberlove
Mar 11, 2021 09:29 AM
Feb 25, 2020 09:57 AM
bearingman07936
Jan 7, 2016 03:22 PM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
