HELP 1st geneZ how low am I?
Qiuck question for the 1st prozzZzzz
i need some camber correction but really dont know how
to measure how low it is call me stupid but
- i have Ground Control w/ Eibach springs
- raised or adjusted to highest point
this might help u out
thanks fellaz
thanks fellaz
Turtle Charged, Biotcch!!
find a stock accord somewhere and measure from the center of the wheel to the fender, then do the same with your car... record the difference. That's how much your car is dropped.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by KLepTo
not low enough
Ingalls camber kits ftw
contrarian in fashion
Ciao Pho Eva eva
Originally Posted by PimpCL23
shiiiiiiiiit.... i got some ebay camber kit for like 50 bucks or some crap and they work just fine!
Originally Posted by Palayah8ta
ur car squeeks like ur molesting a baby cow on an old, rusty bed..
i thought he fixed it already... he even pm me about it...
(Mid-Atlantic)
(Mid-Atlantic)
(Mid-Atlantic)
(Mid-Atlantic)
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by ZeroCL
That smiley is gross.
thanks fellaz
thanks fellaz
why dont you take your car for an alignment? they tell you all the stats of your camber angle and toe settings.. usually
i believe front factory setting is at -0.98? not sure tho
Originally Posted by lnsyone
you dont need a camber kit. you need to lower it a good 5".
ihad to take the front tires off the rim
and switch left to right, right to left
you dont need an expensive kit, i installed a EBAY knock off and it corrected my front to about -1 degrees.. im not killing the inside of my tires anymore now that i installed that. it took me about 2 hours to install.. not to bad. although firestone helped me re-align everything for free after the install
now all i need is a rear kit.. and i should be fine
(Mid-Atlantic)
(Mid-Atlantic)
SidhuSaaB
05-30-2020 12:40 AM
