Headlight removal
Old Jun 4, 2003 | 01:58 PM
23's Avatar
23
Headlight removal
I searched the topic and found one post with a response that didnt help me. I took out the two 10mm on the top then the one the inside where the grill would be and then the one under the car where the air box was for a total of four bolts removed and I still cant seem to get it out. It seems to be sticking somewhere near the fender. Let me know what Im missing here. Thanks
Old Jun 4, 2003 | 02:32 PM
pennykmpr's Avatar
I have a slow car!
there is another bolt under the heatlight, you have to go up through where the fender splash guard is. Look up through were the bumper lights are and you should be able to see it, it is a bitch!!!
Old Jun 4, 2003 | 02:33 PM
pennykmpr's Avatar
I have a slow car!
i just blacked out my headlights a couple days ago. I had to remove the bumper to get them out, (actually i just loosened up the four bolts on each side that supported it. I had to go throught the front air dam on the bottom to loosen them.)
Old Jun 4, 2003 | 03:12 PM
23's Avatar
23
I got one out from going from the bottom, the head of the screw was pointed towards the fender on that one. Is there another one on the bottom of the light? for a total of 5 screws?
Old Jun 4, 2003 | 03:37 PM
pennykmpr's Avatar
I have a slow car!
yeah, there are 5 screws total, one more inside fender!!
Old Jun 4, 2003 | 03:39 PM
pennykmpr's Avatar
I have a slow car!
the two in the fender are about the same distance apart as the top two but the heads of the bolts are facing the fender instead of the sky!! hope that helps
Old Jun 4, 2003 | 03:41 PM
23's Avatar
23
Back to the garage to try again
Old Jun 4, 2003 | 04:07 PM
VXCL's Avatar
AWD Torque Monster
u need to take ur bumper off!! thats how u do it right. it will make install and removal of headlights easier than a $2 ho
Old Jun 4, 2003 | 04:28 PM
23's Avatar
23
I found all the 10mms that last one was a bitch and a half. But the light wont come out with out taking off the bumper. I dont have time for that right now but I will know for next time. For the bumper are there just those 4 10mm or are there more somewhere?
Old Jun 6, 2003 | 09:06 AM
pennykmpr's Avatar
I have a slow car!
little late but there are four on each side in a little square support, wear longs sleeves i have fibreglass all up in my arms after taking that thing off.!!
blacktsxwagon
Oct 27, 2015 10:12 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
rockyboy
Sep 29, 2015 12:05 AM
Desert Ridge
Sep 27, 2015 02:37 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
