Header Install
Old Sep 9, 2006 | 11:18 PM
sixfifty's Avatar
I
Header Install
Jesus christ... this went so horribly. I got the header off the studs, but the bracket was blocking it from coming out, not sure if i gotta take the bracket out or take apart the header in 2 pieces to get it out... It got dark before i could figure it out... how the EFFFFFFFFFFFF do you do it
Old Sep 10, 2006 | 12:17 AM
skeeeeet's Avatar
Its easy. I swapped it in 30minutes. If you need help call me up tomorrow and I can swing by for a little bit. The o2 sensor was the hardest part for me to remove, until I got a o2 sensor socket.
You have remove the 3 nuts between the manifold and downpipe with a long extension from under the car. I believe it was 14mm. Remove the two nuts on the pipe after the o2 sensor so you can take that out as one piece.
Old Sep 10, 2006 | 12:27 AM
shineynitelite's Avatar
NAWWWWSSSSSS
you have to take it apart, thats why it comes apart
Old Sep 10, 2006 | 02:45 AM
klepto's Avatar
yea taking off my headers was a bitch. the bolts were all rusty and old and hard as fuck to reach
Old Sep 10, 2006 | 01:15 PM
skeeeeet's Avatar
PB blaster is great for freeing rusted bolts/nuts. Works way better than wd-40
Old Sep 10, 2006 | 05:24 PM
FULLRACE's Avatar
shit just doesnt come apart as easy at it seems.....theres a process like math. If done right......20 minuts tops. Take the 3 bolts off from the mid section were the upper header connects to the lower half, then remove the header bolts from the head, then remove lower half from the Cat. SIMPLE This is of course after removing the O2. Shouldnt take but 20 or 30 tops even with stuborn bolts.
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
CLsuperhero
Sep 23, 2015 12:53 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
2G-TL-Type-S-03
Sep 20, 2015 12:48 AM
TxRzrBk
Sep 17, 2015 01:07 PM
