Header Install
I
Header Install
Jesus christ... this went so horribly. I got the header off the studs, but the bracket was blocking it from coming out, not sure if i gotta take the bracket out or take apart the header in 2 pieces to get it out... It got dark before i could figure it out... how the EFFFFFFFFFFFF do you do it
Its easy. I swapped it in 30minutes. If you need help call me up tomorrow and I can swing by for a little bit. The o2 sensor was the hardest part for me to remove, until I got a o2 sensor socket.
You have remove the 3 nuts between the manifold and downpipe with a long extension from under the car. I believe it was 14mm. Remove the two nuts on the pipe after the o2 sensor so you can take that out as one piece.
Originally Posted by honda3x23
you have to take it apart, thats why it comes apart ![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
