Has this every happened to anyone?
Old Sep 21, 2004 | 08:17 AM
satinsilvercl's Avatar
#1 Yankees Hater
Just the other day I was drivin and all of a sudden I see my brake light on. Now I know the lever is all the way down so the e-brake is not engaged.
Does anyone know if there is a common electrical problem that I don't know about?
Old Sep 21, 2004 | 08:28 AM
VXCL's Avatar
AWD Torque Monster
if u didnt have the e-brake fully down the light will come on and usually stay on until u turn off the car. the abs light usually comes on also. if u know its not ur e brake go check the fluid it may be low, or the cap may be loose. there is a sensor on it
Old Sep 21, 2004 | 08:29 AM
Anderson's Avatar
Maybe the emergency brake did not fully release after using it? Even though the handle is down it may still be partially engaged.
The sensor that triggers the dash light malfunctioning?
Old Sep 21, 2004 | 08:46 AM
Hobo's Avatar
Flap.
yea this happened to me last winter, very weird, went away
Old Sep 21, 2004 | 08:52 AM
Jamz's Avatar
CAFFEINE SLAVE
are one of your brake lights out?
Old Sep 21, 2004 | 08:54 AM
#1 Yankees Hater
not that I know of. The brake light could be on if I have a brake light out? I never heard of that,
Old Sep 21, 2004 | 08:59 AM
WolfBoy's Avatar
Flamenco Blk 3.0CL PREM
happens to me all the time !! i forget to put the ebreak down completely and start driving .. the ebreak light and the abs light turns on and wont go away unless i turn the car off and back on
p.s. i think there was another light not the ebreak light, that turns on when ur break lights aint working .. anyone ???!!
Old Sep 21, 2004 | 09:06 AM
#1 Yankees Hater
But the thing is, I haven't changed my driving habits one bit and all of a sudden my brake light just went on while I was driving. And I woulda noticed it before I took off to drive.
Old Sep 21, 2004 | 09:10 AM
WolfBoy's Avatar
so did u check to see if the back lights are not out ???!
Old Sep 21, 2004 | 09:18 AM
#1 Yankees Hater
honeslty I haven't. I'll check later today though. I'm kinda hoping that's the reason. Figure a couple of bucks for a light compared to I don't know how much for an electrical fix.
Old Sep 21, 2004 | 09:22 AM
WolfBoy's Avatar
yeah cause i remember when my bulb went, some sorta break light turned on but it was a while ago so i dont remember if it was the same as the ebreak or not .. i guess no one is reading this post to confirm this !!
Old Sep 21, 2004 | 09:23 AM
CLpower's Avatar
teh Senior Instigator
one of your lights is out
Old Sep 21, 2004 | 09:24 AM
#1 Yankees Hater
I know what you mean wolfboy...i need the feedback!
Old Sep 21, 2004 | 10:29 AM
Randol's Avatar
I am not sure about break light coming on when your bulbs are out but I thought that your turn signal flickered faster when any of the bulbs went out you might want to double check but in my integra thats what would would happen (it would click twice as fast). Have not had any bulbs on my CL go out yet so I am not sure.
Old Sep 21, 2004 | 11:03 AM
Skoon21's Avatar
this happened to me last winter... light would go off sometimes after awhile it just stayed on. took it to a brake shop, found that i needed new rear calipers = $600
Old Sep 21, 2004 | 11:13 AM
#1 Yankees Hater
Old Sep 21, 2004 | 11:52 AM
wilp99's Avatar
the problem is the brake fluid resuvoir. the sensors are very sensitive inside. the fluid may be at or just below the full mark and the light will come on, especially when it is cold. just put some fluid in anyways. not much just enough to bring it between the top rim and the max line, and im sure the light will go away.
Old Sep 21, 2004 | 12:57 PM
Smalls's Avatar
Insert Sarcasm Here
I have the same problem. The light will come on when I am driving. After awhile, when I press on the brake the light will go off, then when I release the brake, the light comes back on again. It happens more in the winter time. I know I dont have a light out. Seems lots of first gens have this same problem. I can figure mine out!
Old Sep 21, 2004 | 01:23 PM
#1 Yankees Hater
Wilp99...You had the same thing happen to you? So pour in some brake fluid?
Old Sep 21, 2004 | 02:23 PM
98CLChick's Avatar
My light came on b/c my brake fluid was low, and one of the rear calipers was faulty.
Old Sep 21, 2004 | 09:14 PM
clorich's Avatar
I had the same thing too. Fluid sensor was bad. Try adding fluid first - will probably solve the problem.
Old Sep 21, 2004 | 09:34 PM
Smalls's Avatar
Insert Sarcasm Here
Did any of you have my symptoms?
Old Sep 21, 2004 | 10:02 PM
powderman's Avatar
same thing with me.... first the e-brake light, then abs. turned out to be a loose connector on the master cylinder
Old Sep 21, 2004 | 10:49 PM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
yup thats it
mine was on and i had a left tail light out
Old Sep 22, 2004 | 06:42 AM
KUKICL's Avatar
my abs lightis on will chack today why - but i remember having a brake light out and the only light to turn on was the brake light on the dash
Old Sep 22, 2004 | 08:45 AM
wilp99's Avatar
yea it happens to almost all the 1g's. the sensor is very sensitive. dont over fill it.
the reason why it came on when u had ur foot on the brake is cause the resuvoir drops level when the calipers fill u p with fluid. usually if u got a light on and nothings leaking it means that it is time to change ur brakes. unless it is just below or at the max line.
same thing when winter hits. the fluid is less dense. and it kind of shrinks, making the sensor think its low when its really not. the light usually goes out when the car is warmer cause the fluid expands and makes the sensor think its full again.
Old Oct 10, 2004 | 03:56 PM
DJBOMBERMAN's Avatar
There is a picture of the car in instrument panel that shows a solid red bar when the tail lights go out to let you know that. I had a bad sensor in my Master Cylinder cap so it cause the brake light to stay one, then the abs light comes on as well. It's quite annoying. It is either your fluid level or the sensor could be bad.I had this happen before when my rear brake calipers needed to be replaced. They were leaking brake fluid so the light came on. That was an expensive brake job....just a little over $1300!! just my
Old Oct 10, 2004 | 04:02 PM
#1 Yankees Hater
Found out what the problem was....left rear caliper is all done. Fluid was just leakin all over the place. Had it fixed over the weekend...not too bad of a price ($290)
SidhuSaaB
May 30, 2020 12:40 AM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
Houston
Oct 8, 2015 01:27 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
