Has anyone tryed this stuff (seafoam alternative)
I've used that stuff before on my Legend...worked in quieting the lifters but that's it.
Oil burning stuck around and when changing the oil after using you'll find some goopey sludge left behind by it...
I'd recommend using a product called Auto Rx...its a little pricey but its probably the best cleaner out there...
This is NOT a seafoam alternative. Do NOT suck this through your vacuum tube. This is just an oil additive/treatment like Lucas or whatever that stuff is called.
But if you do decide to suck it through your vacuum tube, like Nate said, deff post a vid...
im sorry but that crap is jsut another BS that autozone markets for noobs who thinks it does anything. im a noob but not to a point where something like RESTORE is gona be in my list. just get a tune up, change the brakes, rotate tires, change tires, ATF drain and fill and yes seafoam. strictly maintence
it actually works to an extent.. but it has to be done properly and i wouldnt recommend it for anyone who uses synthetic oil. i too would rather use seafoam, much more of a universal application.
the bobistheoilguy.com forums has tons of info about all kinds of oils and additives and such....I always suggest that place to anyone with an engineering mind or into cars/mechanics...those guys over there really do know there stuff!
chrisr
12-04-2015 02:17 AM
