has anyone ever tried it?....anyone?????
ok so i was thinking about changing out the gauge cluster and fitting it with the honda s2000 cluster. i kno it works in a civic from wat ive researched but will it fit for our cars. i want that digital look but dnt wanna spend 300 bills on an s2k cluster if its a lost cause... everybody help me out with this one
i was thinking about that but i figure since its electrical that the ecu would tell it what 2 read. just dnt kno if the connections are the same. thats wat im trying 2 figure out
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
It's been done with RSX gauges, not the s2k. I've been waiting for someone to pull of the s2k conversion
you can do it in any car
you just need to buy the cluster/a vss conversion box, and a pulse signal thingy (forgot what it is, but its special to the s2k)...and of course a ton of fabrication to make it fit and look right. If you shop around you should be able to piece all the parts together for like 500 bucks. i personally wouldnt do it unless I had a show car, but I think it looks pretty sick
(Mid-Atlantic)
(Mid-Atlantic)
IMO I dont think the rsx gauges would look that nice in our cars due to the silver center needle trim...looks fine on the rsx since it matches the dashboard trim but on ours it would just look out of place
if you're looking to do a nice cluster swap with good 'out of box' fitment and added extras like illuminated needles, do a 5th gen prelude swap
did it on my 4th gen accord...looked pretty badass at night
One custom CL
No. You're making the entire process way to easy. You have to do a lot of cutting and splicing. You will find the CL gauge cluster pin outs here on azine. S2k id try somewhere else. Gl
word...
with any gauge cluster swap (save the 5th gen accords), you're looking at buying pig tails, buying tons of spare wire....sitting down with 2 pages of wiring diagrams and determining/writing down which wires correspond to what....and a shitload of soldering.
took me around 9 hours straight (including a lot of testing/trial and error) to finally get my lude gauge cluster working correctly in my accord
it's definitely not fun, so you have to determine whether or not the look of a different set of instrumentation in your car is really worth it. It's the primary reason why I havent done the lude swap in the CL...just not really into the nightmare of it all just for illuminated needles and amber lighting.
(Mid-Atlantic)
(Mid-Atlantic)
Paul Walker Status
I'd take these gauges
GuJuLuNaTiC1
03-15-2009 02:49 AM
Billu99tl
09-04-2008 10:32 PM
