H22 trans swap problems
Old Oct 2, 2013 | 08:45 AM
Jbark2010's Avatar
ok guys im new here. I bought a 99 CL with a h22 swap. the clutch was out and it had the original tranny in it. 3rd gear was out as welll. I bought a 92 prelude tranny from a boneyard and a ram clutch from summit and went to town swapping it. Last night i got everything together and went to test drive it. I put it in first and it grabbed a put it in reverse it grabbed i did thi a few times to test it bak and forth and decided to go for a test drive. i backed out ofmy driveway into the street shift from reverse to 1st and the car wouldnt move at all. i can put it in any gear and the car will just sit there running doingnothing. Please helpwith any ideas i really dont want to have to split this trans again but looks like i may have to
Old Oct 3, 2013 | 06:09 PM
SupraManAG's Avatar
One custom CL
id check your synchro rings and springs. Im a little confused though. You went to town swapping it... You swapped transmissions? you swapped 3rd gear? im lost. Is it engaging any gear or have you lost one or more. If your slave cylinder properly bled?
dirtyspitshine
Jan 3, 2023 08:23 PM
justin7779
Dec 25, 2015 10:33 PM
carz0159
Sep 20, 2015 06:11 PM
Skirmich
Sep 15, 2015 06:41 PM
jfman55
Sep 5, 2015 02:55 PM
