H22 swap question?
you can use your stock pumps, alternator, and ac
the only thing you need to replace is the power streeling
cable or wirer whatever that line is called.
reason is that the dip stick gets in the way, just get a prelude line..
Thanks "sumo"! Is there anything else you can give me a heads up on, any little problems that you might have run into? I have the motor here and probably gonna put it in this weekend or the following!
all the mounts on the h22a besides the driver side fit perfect.
take the stock mount from the f22a and on the braket of the h22a drill hole to make that fit.
just look at those pictures, that will help you a bit
Skirmich
Sep 15, 2015 06:41 PM
