h22 cL's vs Prelude vtec
I thought that preludes weight a lot less than our CL, but only a 55lbs difference according to autoconsumer guide. So technically... a CL with a H22 should be pretty much even with a Prelude SH... or be around the same...depending on the driver...weight and ability to drive. yes? Just thought to bring this point up to the ppl with h22s or futre h22ers. If this is a repost...forgive me. i'm bored.
An H22 CL with a 185lb. driver should > a H22 Prelude with a 350lb. driver.
On a more serious note, I think they should be about even. Although, a Prelude should beat a H22 CL on a course due to its superior handling.
My stock 2.3 with Header/Intake/Exhaust kept up with my buddies Lude, and all he had was a fields Unit. He could get me off the line sometimes..but on the highway I could pull him. He sold his car, but I would say that my H22 with the bolt on mods that I have now would BUST HIS ASS!!!!!
Just my opinion.
Just my opinion.
Originally Posted by LCARUCA 97
btw, they quit makin all wheel steering back in like 94. and the wheels dont actually move with the steering wheel, they sway when you go into turns.
ok guys lots of misconceptions about preludes right now:
4th gen ludes 92-96 came in 2/3 models
s model (base) came with the f22..no 4ws (4 wheel steering) or it was optional
si model came with h23...4ws was either standard or optional
vtec model came with the h22
5th gen ludes 97-discontinued(dunno what year) came with 2 models (in US):
base model came with standard h22a
sh model came with standard h22a and atts
now, atts is NOT 4ws
4ws only works during low speed turning to help reduce the turning radius in tight spots (also known as parking lots)...the rear wheels will slightly turn the opposite direction of your front wheels...during high speed turning, the rear wheels will slightly turn at the same direction as the front wheels to help switch lanes during highway driving
atts = active torque transfer system (i think 80% correct)
it's the predicesor a very mediocre version of the sh-awd found in the new rl's...it works as an active limited slip differential...traditional clutch type differentials are passive..and will only transfer 50% torque to each wheel AT MOST...so even if the outside wheel can handle more power during long sweepers, it won't get it...an example: 100hp/tq car will only distribute at most 50hp/tq to each wheel at maximum circumstances
the atts system is an electronic clutch system that can actively transfer +15% torque to the left and right wheels...so if the inside wheel is slipping, it will be reduced to 35% available torque and outside wheel will have 65% available torque...an example: 100hp/tq car can distribute 65hp/tq to one wheel and limit the slipping (useless) wheel to 35hp/tq
so on paper the atts system would perform better than a standard lsd since the atts system will be able to put more power to where there's more traction...but due to heavy machinery (almost 100pounds) and poor computers it didn't do as well as a lighter weight lsd that can perform just as good...how the sh-awd system will do seems much more promising...on paper of course
how much of this do most care about is another question as well...but i just wanted to clear up things
Just my opinion.
Just my opinion.
HE MUST HAVE AN AUTO AND NEED A TUNE-UP!!!! I have had both cars. My CL actually had an H22 in it and I could tell you that my cl with exhaust and intake could kinda keep up with my buddies auto prelude but couldn't touch my other friends 5 speed that knew how to actually drive the car.
And to whoever said the SH is crap, Please drive and know a car before saying bad things about it. I have owned 4 hondas and one of them had the whole suspension done. I have drove plenty of hondas in my time and none of them can hold up against the way the ATTS system turns that dam car. I was amazed when I bought my SH and still am. I rather have an SH which is a bit slower and handles like a science then have a pubic hair of a fraction faster times on the track.
to each is own. I know this but I am trying to give you my thoughts as a HONDA PRELUDE SH OWNER.
oh yeah, there is also a DISTINCT difference between the auto preludes and manual preludes...i've seen auto preludes with basic boltons run high and mid 16's...that's over a second slower than manual
the auto tranny sucks up ALOT of power...even for an auto...some are dynoing around like 140-150hp to the wheels (don't feel like calculating percentages) with basic boltons
some lude owners believe the autos have a less agressive cam profile...believe what you want..but i dunno about that one
well look at it this way. an auto has 4 gears to reach the same speed as a 5 speed manual so the gears are going to have to be longer and therefore a little slower. the more gears you have the closer the ratios can be to acheive the same top speed therefore making it easier to get there. true sports cars have manuals for a reason. thats one of the reasons i dont like automatics. the other is my left foot just gets lonely.
IBankMouse
Jun 13, 2020 12:53 PM
all wheel turning is
