Front Strut Bar
Old May 22, 2007 | 04:29 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
Front Strut Bar
I bought a NRG strut bar for $65 from http://www.koyoaerodynamics.com
It requires some patience and a bolt cutter (or a screwdriver u can mess up and buff arm). I had to relocate my ground wire to and old screw from my OEM intake. But other than that its a 20 min install.
Isnt she sexy!
U need to squeeze it under the fuse box, and remove the stock grounding point with a bolt cutter. Oh.. and i just bent the stock harness holder out of the way a little.. no big deal.
i had to mount it under the ABS line. really easy, just remove the bolt and slip it under.
Old May 22, 2007 | 05:19 PM
CLpwner's Avatar
Mmmm...
Old May 22, 2007 | 05:26 PM
STL+3.0CL's Avatar
Matt
Im assuming this will fit the 3.0 also ?
Old May 22, 2007 | 06:10 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
yea but i dont know what u have to move to make it fit.. maybe blackack can enlighten us.
Old May 22, 2007 | 06:31 PM
Sleep_DEPRIVED_Sleeper's Avatar
Turtle Charged, Biotcch!!
It should fit the 3.0, the body is the same.
According to the pic, you won't have to take off the ABS bracket and put it back on or relocate the ground point.
The only thing you migh have problem with on a 3.0 is the bar touching the vaccumn (sp?) hoses on the IM. You can see my strut bar touching the hoses in the pic above... I have tilted the bar at an angle for clearance, but i dont think you can do that with an NRG bar....
To the OP: How high is the bar? from the strut mount bolts to the height of the bar in the middle...
Old May 22, 2007 | 06:37 PM
I forgot to add and the server doesn't let me edit my post:
If you have the stock 3.0 strut bar, you need to remove it along with some wire mounting clips. After the strut is off, you'll have a small bracket standing in the way. Use a hammer to flatten it or remove it anyway you like.
idk if you'll have this bracket problem but i did, just FIY.
Old May 22, 2007 | 06:44 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
my car is funky because so much shit has been taken off and put back on my car, stuff thats super easy for me, is hell to other people. the NRG bar is level to where the stock strut bar wouldve been.
I didnt buy a strut bar like yours because when i bought one for my GF's accord, it looks like it could flex pretty easily, defeating the whole purpose of the bar.
Old May 22, 2007 | 07:00 PM
Yea, it's generic ebay bars, i bought it in a set. I'm gonna replace it soon with a Cusco/Tanabe bar. The NRG bar looks very nice.
Old May 22, 2007 | 08:03 PM
Cocoa's Avatar
2600lb CL
beautiful!
Old May 22, 2007 | 08:09 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
Talking
thanks guys.. the nrg one is pretty good for the $$
i REALLY need get rid of some unneccesary lines/hoses and clean my engine bay..
Old May 22, 2007 | 11:25 PM
99CL's Avatar
blah blah blah
That's a nice looking bar. Engine bay is looking good...so sexy.. =)
Old May 22, 2007 | 11:27 PM
99CL's Avatar
blah blah blah
It should fit the 3.0. Only problem you might have (which I had with my cusco bar) is a braket on the passenger side. All you have to do is hammer it down or knock it off and it will fit just fine.
Old May 22, 2007 | 11:39 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
The bracket is the only problem for the 3.0, nice pick up daniel, I bet that stiffens up them omnis a bit on turns, less body roll. I have an NRG bar too that I was gonna put on those omnis too when I had them
Old May 23, 2007 | 12:51 AM
Palayah8ta's Avatar
Ciao Pho Eva eva
ya know i was testing it out today, and it affects the bounciness of the ride.
when i hit a bump on a turn i dont feel it at all like i used to. I think instead of the suspension making me feel the bump twice, it just bounces once. I like !
Old May 23, 2007 | 04:13 AM
NitiNiteZ's Avatar
The Hefty 2.2
i thought ppl said the stock front strut bar was pretty decent since it was one piece. So would you say for the money, replacing the stock front strut bar is worth it? or is it more for looks than anything?
Old May 23, 2007 | 07:46 AM
ZeroCL's Avatar
W WHIP.
Good question, I want to know too!
Old May 23, 2007 | 08:00 AM
(Mid-Atlantic)
It definitely serves a purpuse, just like the lower strut bar, because it ties the two struts together rather than the chassis, providing for less twist
Old May 23, 2007 | 09:07 AM
STL+3.0CL's Avatar
Matt
Yea, but the stock one in our cars is fairly strong. Your gaining more of a custom "look" than you are performance.
Old May 23, 2007 | 09:45 AM
Ezekiel25_17's Avatar
The stock ones are 3 point braces right? I heard that was a lot better than the 2 point braces. What would be a good mathematical way to measure which of the two are better?
Old May 23, 2007 | 10:04 AM
(Mid-Atlantic)
personal preference
Old May 23, 2007 | 12:23 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
Ok the stock ones mounting point is wierd. THe middle part can be bent very very easily, and the bar is attached to the wheel wells. I honestly dont see how it works very well.
ALso dont buy the strut bars that look like this:
the're very weak and more for looks..
See the Cusco ones are designed like so:
And the NRG one is like so:
BUT all in all, I suggest getting an aftermarket bar only if u have coilovers. if ur on stock suspension, its not going to do shit.
Old May 23, 2007 | 12:34 PM
(Mid-Atlantic)
The stock one is OK for the STOCK suspension, not aftermarket suspension or performance.
Old May 23, 2007 | 01:09 PM
Shoshinsha_KiDs_CL's Avatar
sold!
good pick up! engine looks nice
Old May 23, 2007 | 01:24 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
thnx, hey u coming to the all cali meet? june 30?
Old May 23, 2007 | 01:31 PM
1V4N's Avatar
1st Gen CL Noob
Nice looking bars!
Old May 23, 2007 | 02:00 PM
h2o-pr00f's Avatar
Im No Superman
I wish I had coils
Looks nice D, is it worth it w/ my drop? The body roll is still annoying and I dunno about $250 for a stuff like William has, I have other things I gotta take care of on this car 1st
Old May 23, 2007 | 02:18 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
i dont think ur setup is stiff enough for this to help. U are better off with a rear sway bar 1st
Old May 23, 2007 | 05:43 PM
Cocoa's Avatar
2600lb CL
Originally Posted by h2o-pr00f
I wish I had coils
What drop do you have?
Old May 23, 2007 | 05:44 PM
(Mid-Atlantic)
Front and rear sways will benefit you way better than strut braces
Old May 23, 2007 | 06:16 PM
h2o-pr00f's Avatar
Im No Superman
Flipping pro kit w/ tokico blues
Old May 23, 2007 | 07:50 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
i second that
Old May 23, 2007 | 07:55 PM
sold!
not sure.. but i will for sure go to the SD meet
Old May 23, 2007 | 07:59 PM
CLpwner's Avatar
Mmmm...
I wish I lived in Cali...
Pause
NOT kinda...
Old May 23, 2007 | 10:08 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
Pause
NOT kinda...
OMG Becky!! U wish u were out here!! Best weather, Hottest girls, No rusted bolts or rusty fenders. And i can drive my lowered CL all year without breaking it!!!
Nevermind the smog and traffic and 1 bedrooms costing $1500 a month
Old May 25, 2007 | 01:58 PM
Dez97CandyCL's Avatar
...nO phOtOshOp...
it looks like the bolt securing ur ABS lines isnt in the hole... jus a keen observation...
oh by the way... H22CL+NRG Strut Bar =
Old May 25, 2007 | 02:41 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
the bolt was tightened more-so after i saw the picture on my computer.. Lol
Not bad for a camera phone eh!
marcelft
Jul 10, 2018 06:17 PM
acurajj
Feb 14, 2016 02:28 PM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
Heyzuez20
Oct 14, 2015 07:18 AM
08 NBP TL
Sep 8, 2015 08:49 PM
