foglights question..
nippon_wa 2.0
so.. I have stock fog lights on mine..
but after I put the bodykits in, I took 'em off cuz they don't fit..
so.. here's question..
if I buy some small aftermarket foglights, can they be connected w/ stock foglights harness??
i'm looking for getting piaa ones.. and can they be hooked up?? or i have to rewire everything again??
if it's possible, anyone wants my stock foglights?? w/ piaa bulbs in it??
thanks
thanks
Received 7,476 Likes
I highly doubt PIAA lights will interface w/ stock harness. I had mine installed (on a Wrangler) at Acura for $110. PIAA has a special relay and switch that will sit somewhere, inconspicuously, in your interior.
nippon_wa 2.0
I don't know how much I would sell 'em... never thought of selling 'em..
if the stock harness works /w piaa, I might sell the foglights only..
but if they don't work, then I'll sell whole things..
maybe.. $100ish? I don't know..
at this point, selling 'em is not the point.. I want to know if the piaa works w/ stock harness..
My Home Planet
You can use the stock harness but only to a point. Obviously, you would have some wire splicing to do. I'm not familiar with what power requirements the piaa's have, but you may need to remove/add a fuse or two. Maybe even a relay. It will not be a simple plug and play conversion. Basically, the wires can be used but may required add-ons. It really depends if you want to cut up the existing harness.
its probably not that hard nippon.. just changing a wire here and there
we could probably install it in 1 hour.. two minds are better then one!
PIAA foglights are expensive though.. my
btw.. im pretty sure all foglights are made so any H4, H3 bulb could fit.. i hear that some foglights even take in 9006 bulbs..
its paid for
As everyone has said its not as simple as plug and play. It should not be hard though. I think piaa has a fuse and a relay...and the oem setup should have both of those. So it might be as simple as just changing the wiring at the end where you plug the actual lights in.
nippon_wa 2.0
thanks for the info guys..
and.. legendary.. u r welcome to buy mine!
and.. do u think u can install the foglights in? or anyshop??
i know piaa's are expensive... but i'm getting one when i have $$
i dont think it'll be that hard
probably just extra wires.. and electric tape is needed....
maybe a few screwdrivers too
tell me when your gonna buy them.. ill buy the stock ones off ya
Originally Posted by legendaryCL98
u cant buy the stock wiring!! i need that!! with the foglights im buying off him.. lol..
cheater!
cheater!
no.. i live in the same city as him.. haha
i could just go pick it up
Anyway it probably would be easier for you to get them Im just going to try and find some closer to Houston.
nippon_wa 2.0
Originally Posted by Randol
If he sells how about first come first served I beleive that would be me buying them.
but since he's in local, it's more easy for us.. so.. sorry
quanaman
01-09-2023 07:33 PM
shinybluecls
11-16-2005 12:00 PM
ST2000
08-14-2003 02:47 PM
