Flush mountingafter market deck.
Old Feb 5, 2004 | 04:20 PM
njpdiddy's Avatar
For all those who have used the factor "cubby hole" and flush mounted thier aftermarket deck how did you do it??
Old Feb 5, 2004 | 05:13 PM
dennis's Avatar
That's my pic!!! That was the old deck I had. I used a custom mount bracket in the back to hold the top deck up so it would sit staight out. If it didn't have the bracket I made, it would sag a little. I also used weather striping about the deck to fill the gap. The weather strip was black so everything looked good.
Old Feb 5, 2004 | 05:30 PM
njpdiddy's Avatar
How did you make the bracket???
btw what branch of service are you in??
Old Feb 5, 2004 | 07:03 PM
rmh3093's Avatar
Pass the dutchie!
I made a custom mount also. What I did was bought this strip of metal from homedepot. It is about a 1.5" wide and a few feet long. It is flat and has .5" holes along its length. I bent the metal so that it looks like a "U" then bent the 2 adjacent sides 45 degrees so that go flat agains the side of my cdplayer, it screws right in and use the mount from the oem stereo to attach my new mount the the chasis of the car.
Old Feb 5, 2004 | 07:50 PM
njpdiddy's Avatar
Thanks for the info. You got the deck I wanted too, but I got the P7500
Old Feb 5, 2004 | 08:22 PM
dennis's Avatar
I took a "L" shaped piece of aluminum and drill 2 holes in it. When you take out your stock cd player, there's a piece of metal with 2 holes in it. Thats where I screwed the "L" piece to. Since the deck was shorter than the stock one, the "L" made it sit up more and allowed the cubby to sit straight also.
BTW: I'm in the Air Force. "Aim high"
Old Feb 5, 2004 | 08:28 PM
njpdiddy's Avatar
Thanks!
BTW: I'm in the Marines I wish I aimed high.
Old Feb 5, 2004 | 09:06 PM
baka_t's Avatar
The movement has started
I custom fabricated a whole metal housing that screwed into where the stock one went.
Old Feb 5, 2004 | 10:16 PM
green972.2's Avatar
mine looks like those... duct tape and zip ties work great
Old Feb 5, 2004 | 11:03 PM
wakeboardfusion's Avatar
Miss th 3.0
u can get them @ autotoys.com
Old Feb 5, 2004 | 11:08 PM
Zerostatic's Avatar
100% Dominicano
What is that on the monitor?
Old Feb 6, 2004 | 08:17 AM
dustbuster4's Avatar
A-CL Post Whore w/N2O
The 1st pic is mine.
The cubby hole is not there, in that pic. I just peeled the wood grain off of the cubby hole, and put it over the "knock out plate" that covering the space.
My deck sticks out like an errection!
Old Feb 6, 2004 | 09:26 AM
MaCe's Avatar
fellow MASShole
mine went in fine with a dash kit ... i gotta do some messin around so i can get the little cubby thing with the cover in there
Old Feb 6, 2004 | 10:11 AM
CLpower's Avatar
teh Senior Instigator
man, i need to get into stereos!
Old Feb 6, 2004 | 11:24 AM
MaCe's Avatar
fellow MASShole
still stock scott?
Old Feb 6, 2004 | 11:51 AM
99CL's Avatar
blah blah blah
CLPower...don't get into car audio. If you end up liking it too much, you're gonna spend BIG MONEY....I've spend a few Gs on mine, and keep changing stuff all the time...of course it's for better stuff....
Old Feb 6, 2004 | 12:06 PM
ju5tchi11in's Avatar
roomate has a CL too
the deck came with a strip of aluminum which has pre drilled holes all along it... in the directions it saids to bend it into an L shape and then it should fit I got the Pioneer DEH-P850MP. Is this what you did?
BTW njpdiddy I was about to start a this exact thread. lol good one beat me to it.
Old Feb 6, 2004 | 03:33 PM
njpdiddy's Avatar
Well this is the outcome so far I just have to fill in the gaps on the sides.
Old Feb 6, 2004 | 04:33 PM
dennis's Avatar
I think you're talking about the cover plate. It prevents thiefs from taking the headunit out. You have to bend tablets so if you pull on it, it won't come out. The "L" bracket I'm talking about is a piece of thick aluminum I had to custom fabricate myself. It's kinda hard to explain.
Old Feb 6, 2004 | 04:35 PM
dennis's Avatar
Looks good! Take some black weather stripping and fill the gap. That's what I did. Make sure you get some thick stuff. They sell it in a roll.
Old Feb 6, 2004 | 06:13 PM
rmh3093's Avatar
Pass the dutchie!
yeah looks good man, there are actually 5mm deep support holes on the side of the Pioneer decks so if u plan well u can make it so you can screw your bracken right into the headunit, thats what I did, I dont see how anyone could steal that unless they destroy the car
hashbrown
Sep 29, 2015 12:13 PM
08_UA7_Gr33k
Sep 27, 2015 12:42 PM
kev87a
Sep 26, 2015 02:30 PM
blackwarrior
Sep 26, 2015 09:09 AM
agupta3224
Sep 22, 2015 02:37 PM
