Fix: Dimming lighting when using blinkers
Bagel Bomber
I've been chasing this problem down for a few years now, 3 to be exact. For reference:
http://www.acura-cl.com/forums/showthread.php?t=159031
When using my blinkers, the lights in the car, including headlights at nighttime would dim in response to the increased load the blinkers were drawing. It was not only the blinkers, it was any load put on the car, including sun roof, heated seats, windows, anything. Well, my alternator finally went out recently and I had it towed to Pohanka Acura. They replaced the alternator and battery. They found a bad diode. I was hoping the new alternator would fix this problem, but it didn't. After being invited back to have them look at the car again they were able to fix the problem. This is word for word what was written on my paper work:
"Found virtually every load in the vehicle receiving varied voltage input when blinkers were in use. Inconsistent voltage causing any light to have a slight strobe or flash effect. Determined fault to be present in every circuit suggesting a charging system error. Examined the "ELD" (Electrical Load Detector). Found ELD supplying PCM with varying and inconsistent commands/inputs, thus forcing the PCM to constantly switch the alternator from high to low output, causing a vehicle wide condition. Suspect after market bulbs of varying and difference from stock resistance causing an average amperage draw slightly different than stock. The new average draw falls in a gray area of the ELDs logic mapping software, making it difficult /impossible for the ELD via PCM to correctly command high/low operation at idle. If loads are added/taken away, or RPM brought up, problem diminishes. Bypassed ELD to create an always high condition/command for the alternator. This will have zero adverse effects."
This was done free of charge. I've been taking my car to the "stealership" since I bought it, and will continue to do so. Not all dealerships are the same but Pohanka Acura in Chantilly VA has always done a stand up job. Thanks
As far as the suspect after market bulbs, they are LED's. (you can search my started threads for pictures) I put these bulbs in last year, 2006, but as you can see the problem has been in there since 2004. Guess they needed to be able to point at something and say this or that was the cause. Either way, I think this will help a lot of people since there are 4 pages of people in that other thread with similar problems.
Good info to know. I have the same problem with my car only its intermittent. (It only happens once and a while) Though I thought it was because my alternator is going bad. Or it's because i'm running alot of sounds and monitors drawing excess power for my stock alternator to keep a charge. The stock alternators amps are only 105. So i'm thinking of putting in a High Output Alternator of 205 to see if that will help out. Or just put in the Hyper Ground system with a larger Battery Cap for the sounds.....
~[ô¿ô]~
I remember many years ago there was a bulletin explaining people noticing the "dimming effect" during Daylight Saving switch over. The bulletin referred to the ELD being the culprit, but it didn't mention you could bypass it without adverse effect. I'll give that a shot.
I like how Pohanka is open till around 11pm. Thanks for the info!
Bagel Bomber
Sounds like you know where the ELD is....mind sharing, i'd like to see what they did? Yeah they are open until midnight, worked out great in this case.
Originally Posted by AcAttAcK98
How much would that job normally run at a shop?
~[ô¿ô]~
Lights Dimming and the ELD
NOTE: This article applies to all Acuras except the SLX.
Soon after the change from daylight savings time to standard time (the last Sunday in October), Tech Line gets numerous calls about flickering or dimming headlights or dashlights when brakes or turn signals are used.
This flickering or momentary dimming happens when the battery is supplying most of the electrical load, not the alternator. It’s something customers are more likely to notice when the during their dark evening commutes that start with the change from daylight savings time to standard time. If your customer complains about the lights dimming, tell them about the ELD and how it works.
Since the early ’90s, all vehicle charging systems have an ELD (electrical load detector). The ELD sends a signal to the ECM/PCM that’s proportional to electrical demand. The ECM/PCM then switches the alternator between normal and low output depending on several factors, which include electrical demand, battery charge level, and the driving cycle. When the alternator is off, the engine load is reduced and fuel economy improves.
Unless the vehicle won’t crank or it has other symptoms of a weak battery, the lights dimming is probably not a sign of electrical or charging system trouble.
POW POW (01-22-2013)
I was just wondering if anyone figured out how to bypass this ELD??? My car does this to and now it's becoming very annoying! Before I decide to take it to the dealer I was just curious if someone out there with the same problem bypassed it or figured out another way of fixing the problem......
Bagel Bomber
Unfortunately, I have no idea where the ELD is located. I'd love to know though. Maybe next time i'm in for an oil change i'll bother them to show me the location and i can see how it was bypassed.
Bumping this to see if any updates. I know where the ELD is but I havent looked at it yet to see how easliy it can be bypassed. I know it is located in the Underhood fues/relay box. I am going to try and fix this problem this weekend in the process of doing other car maintenance. I also know the other fix requires removing #2 pine white green wire from connectorC131. Where is connectorC131. I tried searching but came up with nothing
Bagel Bomber
When i talked to the Tech - I thought i heard him say he pulled a pin out of the connector so it was a clean bypass, basically it isn't hooked up anymore.
I hate to bring back post from the dead but this post never got resolved. Anyone who had this problem and fixed it can you tell us what you did? I have the same exact problem bought an optima battery yellow top didn't fix it so i took it back...bought a new alternator didn't fix it so I hopefully can take it back...im good at fixing car on my own but I just need a tsb or something to show the location of this Pin and connector. Anyone please?
Thanks,
smgtech.
Thanks,
smgtech.
Fix for dimming lights while directions operating
Hello,
I am selling a 1998 CL for a friend and had it all ready to go when I noticed this weird light dimming thing while the lights and directionals were on at the same time. I was directed to this site and read about others trying to find a cure for this issue.
I've owned an auto electronics business for 23 years and I love a good challenge, so here's what I did: I connected a wire to the white wire w/green tracer at the 4 wire alternator connector. I ran this wire up to the larger of the two fuse boxes under the hood on the passenger side, closest to the windshield.
There are some unused ports where fuses would go if they were needed for optional equipment. I tested these ports with my test light to see which one goes hot with the key in the ignition/run position (not constant battery power). I used a male spade connector crimped to one end of a 10 amp glass fuse holder, then connected the other end of the fuse holder to the wire coming from the alternator connection. I put the wire in some black flex-loom tubing for that nice factory look.
Problem solved-no more disco lights!
Back from the dead!!
For those still interested, I have some info on this. Found an article about the alternators on these cars. Here's a pdf found on google. I had problems opening it but could read it in the "quick view" link.
https://docs.google.com/viewer?a=v&q...nskQiIiWmuA0Yg
What 98cl3.0L was saying is that by jumping that wire it tricks the alternator into thinking it needs to be charging. From the factory the computer controls it using the ELD and at low speeds and RPMs its putting out low voltage.
The ELD is located in the fuse box under the hood on the passengers side. Try replacing the fuse box with a low mileage unit or a new one$$.
Or try jumping that wire with a switched 12v from the fuse box and the alternator will be charging all the time. It should be the bottom right wire looking from the back of the alternator.
I'll be working on this in the next few weeks.
Hope this helps!
Hope this helps!
Update: I replaced the fuse box with a low millage unit from eBay and the code is gone. However, the lights still slightly dime at idle with the blinker on....
In case you're wondering the car has a new alternator and battery.
That's all for now.
That's all for now.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Check your grounds and alternator connections
mada51589
05-03-2022 08:54 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
