engine problems again
Old Oct 13, 2005 | 07:32 AM
froggystyle14's Avatar
"FROGGYSTYLE"
if some of you remember in the past i have posted about a miss in the engine. well the other day my distributer bearing went out and replaced it under warranty, great put it on and still had a small small miss. Lastnight i was driving around and i felt it miss so i held it there so it would throw a code, it did and said: Throttle/Pedal Position Sensor/Switch A Circuit High Input which is the tps, but now this morning is startd missing so bad that the motor was jumping front to bad like it was on hydrolics. any help is appreciated
Old Oct 13, 2005 | 07:45 AM
SupraManAG's Avatar
One custom CL
What is this TPS malfunction season??!!!
My TPS is being gay. Regardless that I changed it, regardless that I cleaned the whole throttle body and it still acts up. It will be fine for 3 weeks then one day it will go off like a motherflupper then be fine the next day.
Old Oct 13, 2005 | 07:48 AM
"FROGGYSTYLE"
some luck we have....but would the tps make the motor jump front to back alot??
Old Oct 13, 2005 | 11:46 AM
SupraManAG's Avatar
One custom CL
If its reving like a maniac then yes.
When my engine light comes on i know that my rpm will not be constant i might aim for 3k and as im letting go off the clutch thr rpm will drop to 1k then surge back up. Thats a normal malfunction then it gets worse where i have trouble driving the car.
Old Oct 13, 2005 | 12:20 PM
ghost_masterCL's Avatar
isn't the TPS a recall for you 2.x guys?
Old Oct 13, 2005 | 12:54 PM
"FROGGYSTYLE"
dont know....let me try to detail my problems. im the mornings, it is ideling at 3k, taking off at a slow rate i can then mash the gas down and you feel the car miss, hessitating, and then bammm it throws you back in to your seat like a v8. any time i am between 2500 and 4k, you can feel it missing really badly, it has dropped my gas from 31mpg down to 22 mpg, every time i let off the gas it sounds the the "CRAZY FROG" song, push the gas down and it misses again. Now if i am at WOT, the S.O.B. runs like a scalded dog.
Any advice besides "Your Fu****" is greatful
Old Oct 13, 2005 | 01:19 PM
SupraManAG's Avatar
One custom CL
I had that happen once only.
It rained a lot and i had to go thru some deep puddles of water. Don't know if theer is a connection between the two but the car would rev fine up to 2.5-3k then it was like I would press the gas and nothing would happen then BOOM 8-9K and Id lauch like a maniac.
My solution?? I parked the car, went home, prayed that it was all a dream and the car was fine the next day.
There are two things I would suggest to you.
1 . Take out our throttle body, remove the TPS sensor and clean the throttle body with throttle body cleaner.
2. Get yourself a new TPS. Do not call Acura because they will want to sell you a new throttle body with TPS for $700. Either get a new one off e-bay or find another Honda engine and take it off that one. They all all the same.
Old Oct 13, 2005 | 01:33 PM
"FROGGYSTYLE"
cleaned the throtle body and the intake manifold already. i guess i could do it again. my dad thinks it is in the wiring some where. i dont know. oh well.
Old Oct 13, 2005 | 06:18 PM
SupraManAG's Avatar
One custom CL
If you didnt touch the wiring it wouldnt just fuck up. Change your TPS. Leave you throttle body in brake fluid overnight.
Old Oct 15, 2005 | 08:13 AM
"FROGGYSTYLE"
found an injector seal leaking so i replaced it and it took away my miss, but 30 mins later it came back. check my injectors again and they are fine now what?
Old Oct 15, 2005 | 10:06 PM
"FROGGYSTYLE"
n e one else have any input?? this shit is sucking my gas mileage
pizokk1
Sep 17, 2015 09:29 AM
Billu99tl
Sep 13, 2015 11:30 AM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
