engine problems
Old Feb 19, 2006 | 12:55 AM
doug cl's Avatar
engine problems
I am trying to help my brother with his 91 honda accord. He is having problem with his car. When he turns his car on the rpm goes up and down. The car runs fine but every time he stops his cars' rpm goes up and down. I know I am posting this on a cl forum. any suggestions?
Old Feb 19, 2006 | 02:26 AM
NitiNiteZ's Avatar
The Hefty 2.2
my brothers car use to do that when his air conditioning was on.. or the air condensor working (heat or a/c)... so we just shut it off when we were at stops... good luck
Old Feb 19, 2006 | 02:50 AM
SupraManAG's Avatar
One custom CL
You either have a vacuum leak somewhere along your lines in which it is causing your rpms to surge or your TPS sensor is dirty or broken.
Old Feb 19, 2006 | 12:06 PM
doug cl's Avatar
it also happens when the a/c or heat is off
Old Feb 19, 2006 | 12:49 PM
ajtcl's Avatar
Peace, Love & Acura
Check vacume lines and ECU connections for IAC, BARRO and MAP, you may have falty or disconnected sensors. This has nothing to do with the a/c.
Old Feb 19, 2006 | 08:21 PM
doug cl's Avatar
thanks for everything
Old Feb 19, 2006 | 09:04 PM
ghost_masterCL's Avatar
egr?
Old Feb 20, 2006 | 01:04 PM
xrunner86x's Avatar
A-CL Totaled Member
clean the idle control valve, there are instructions if you search. if thats not the problem, it couldnt hurt anyway.
Old Feb 20, 2006 | 02:22 PM
nggasaywhat's Avatar
dam your fucked
Old Feb 20, 2006 | 02:30 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Originally Posted by nggasaywhat
dam your fucked
Tell em alex
Old Feb 20, 2006 | 02:33 PM
well....its the truth they should ove just left me alone....but noooo. Now im all rebelious like.
Old Feb 20, 2006 | 03:00 PM
SwervinCL's Avatar
Nom Nom Nom Nom
So much for keeping it on the DL!
Old Feb 21, 2006 | 12:26 AM
SupraManAG's Avatar
One custom CL
Dude change your age to something realistic. Nothing you have said or will say pertains to your age. Goodluck
pizokk1
Sep 17, 2015 09:29 AM
Billu99tl
Sep 13, 2015 11:30 AM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
