Engine Problem
Engine Problem
Hey friends.
I haven't had many major problems with my car in the past (mechanics-wise).
But I actually started having trouble with something today.
I was driving up Semoran Blvd (major road in Orlando)
and my car starts to bog.
Im going from 1st - 2nd - 3rd and I'm in the realms of 1,000rpm - 2,000rpm.
Its like I hit the gas and the car won't move, I'll let off the gas and then punch
the gas quickly, not WOT, but i'll punch it because it feels like the "throttle is sticking".
I just filled her up with 93 octane. I plan on throwing some fuel additive when
I fill her up next. My thoughts on this are (what it could be) :
1. Fuel Line (Pump, Filter, Fuel itself - aka tainted gas)
2. IACV - Something to do with the Air intake of the engine (I checked, my filters clean)
3. Transmission - I doubt it, because I know my shifts and I know a bad shift when I
hear one.. This one has to do with the motor, but I am not ruling out that my
clutch packs for 1st - to - 2nd could be hurtin'
4. Motor - Oil is not leaking, nothing is leaking-- I'm clueless there
Originally Posted by Danil ACE
You do realize that 93 octane does nothing more for the CL than 87 octane, right?
Although you should use it once a month or so...it's good for your injectors. Normally its a waste of money.
i feel like its something electric.
the car vibrates and sometimes just doesnt want to go forward
unless i let off the gas and then punch it again (sometimes takes a few tries).
It sounds crappy at idle too.
I really hope my transmission isnt fucked.
I have a 3rd party warranty on the car,
I'm scared that whatever the problem is, its not covered.
P.s. I have no leaks.
seafoam dat bitch lol do both engine and tranny(need the special tranny one) if that dont fix your problem then it leaves iacv or tranny bout to die. also could be ur spark when was the last time they were chnged?
alternator... i know it sounds weird, but thats an old school problem and i dont know if that would happen to a newer car.
edit: actually read you were 1st gen... im really sure its an alternator or the battery. autozone will test them for ya for free.
my car started boggin a little after I took it in for the recall. I just made an appointment to go back. i'm hoping it's something simmple. mine happens between 2 and 3 thousand RPMs.
I thought maybe compression
cuz I could be just cruising and I'll start getting a gerbling noise. anyone have an idea?
funny thing is that I tested this out on my G-meter timers............. and the CL did better on 87 than it did on 92
I get way better gas mileage with 93, but that's me
Does your gas pedal have to have an unusual amount of pressure pressing on the pedal to get the RPMs up??? Mine's been doing this lately...I know I have a Leak in my B-pipe, btu could this be a result of a bad EGR valve? Easy fix?
I just remembered that i still have the top intake manifold, and TB from when i parted my first gen... Soo thats always an option. Its got 52 miles on it as I painted my first one all silver with red accents and swapped it to the other first gen that i had. So if you want that, I can sell it to you.
Originally Posted by legendaryCL98
maybe you need new plugs?
or only the fuel filter.
or only something simple.
I installed a ground system today and it did nothing.
I'm at the point where I'm depressed over this shit.
I love my CL and this is really putting a damper on life.
^ the truth hurts.
I might bite the bullet and drop the car off at the Honda dealership tomorrow.
( i have an extended waranty )
I've seen it for $3.55 closer to seattle.93 is 20 cents more per gallon, and most of my driving is stop and go (not too much freeway), so my gas mileage sucks anyways.
87 here costs $3.43 per gallon
dude!! we just hit 4 bucks today in the dirty parts of seattle for 92!! im going crazy!
We're on that way too, hope that doesn't come here
same here. $3.40 for 93 n my H22 wont run on anything but that.
I get my gas in NJ for about $.50 less per gallon.
As far as the problem my car has been acting up big time too. I need to clean my IAC plus seafoam. Oil job, air filter n clean spark plugs.
maybe a Tein SS-P next week
Originally Posted by zhouz
last time that bogging thing happened to mine (sounds just like your problem) it was my ignition wires.
if these are spark plug wires, then where are the ignition wires?
^ for the IAC, do I just get in there with a brush? that's just a sensor right? cuz I took it back to the dealer twice and they said it was a "loose" plug wire. I think that's bull but I don't wanna drive 20 min just to have them gimme the run around. but I can't stand this puttering.
Billu99tl
Sep 13, 2015 11:30 AM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
