Engine Problem
Old May 9, 2007 | 04:34 PM
dragon084's Avatar
1999 CL3.0
Engine Problem
Hey friends.
I haven't had many major problems with my car in the past (mechanics-wise).
But I actually started having trouble with something today.
I was driving up Semoran Blvd (major road in Orlando)
and my car starts to bog.
Im going from 1st - 2nd - 3rd and I'm in the realms of 1,000rpm - 2,000rpm.
Its like I hit the gas and the car won't move, I'll let off the gas and then punch
the gas quickly, not WOT, but i'll punch it because it feels like the "throttle is sticking".
I just filled her up with 93 octane. I plan on throwing some fuel additive when
I fill her up next. My thoughts on this are (what it could be) :
1. Fuel Line (Pump, Filter, Fuel itself - aka tainted gas)
2. IACV - Something to do with the Air intake of the engine (I checked, my filters clean)
3. Transmission - I doubt it, because I know my shifts and I know a bad shift when I
hear one.. This one has to do with the motor, but I am not ruling out that my
clutch packs for 1st - to - 2nd could be hurtin'
4. Motor - Oil is not leaking, nothing is leaking-- I'm clueless there
Old May 9, 2007 | 06:10 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Sounds like the IACV are u throwin any CEL's or codes?
Old May 9, 2007 | 06:28 PM
dragon084's Avatar
1999 CL3.0
no codes.
its almost like it wants to stall.
i dot know any mechanics out here
Old May 9, 2007 | 08:38 PM
duluoz's Avatar
HEET Miser
injectors?
bottle of techron worth a shot for $15
best of luck
Old May 9, 2007 | 08:46 PM
Danil ACE's Avatar
Sounders FC
You do realize that 93 octane does nothing more for the CL than 87 octane, right?
Old May 9, 2007 | 09:24 PM
Dicorp's Avatar
Although you should use it once a month or so...it's good for your injectors. Normally its a waste of money.
Old May 10, 2007 | 01:15 AM
dragon084's Avatar
1999 CL3.0
i feel like its something electric.
the car vibrates and sometimes just doesnt want to go forward
unless i let off the gas and then punch it again (sometimes takes a few tries).
It sounds crappy at idle too.
I really hope my transmission isnt fucked.
I have a 3rd party warranty on the car,
I'm scared that whatever the problem is, its not covered.
P.s. I have no leaks.
Old May 10, 2007 | 01:49 AM
spiderman3098's Avatar
seafoam dat bitch lol do both engine and tranny(need the special tranny one) if that dont fix your problem then it leaves iacv or tranny bout to die. also could be ur spark when was the last time they were chnged?
Old May 10, 2007 | 02:56 AM
mohaukachi's Avatar
upgrade
alternator... i know it sounds weird, but thats an old school problem and i dont know if that would happen to a newer car.
edit: actually read you were 1st gen... im really sure its an alternator or the battery. autozone will test them for ya for free.
Old May 10, 2007 | 06:29 AM
sumdumguy's Avatar
a jawful a somethin awful
my car started boggin a little after I took it in for the recall. I just made an appointment to go back. i'm hoping it's something simmple. mine happens between 2 and 3 thousand RPMs.
I thought maybe compression cuz I could be just cruising and I'll start getting a gerbling noise. anyone have an idea?
Old May 10, 2007 | 07:10 AM
G22_Powered_YA1's Avatar
funny thing is that I tested this out on my G-meter timers............. and the CL did better on 87 than it did on 92
Old May 10, 2007 | 08:44 AM
(Mid-Atlantic)
I get way better gas mileage with 93, but that's me
Old May 10, 2007 | 09:16 AM
STL+3.0CL's Avatar
Matt
I have noticed, that I get decent mileage on 87 and 93. But when I use 89 midgrade I get great mileage ??? any thoughts on why
Old May 10, 2007 | 09:18 AM
STL+3.0CL's Avatar
Matt
Could be leaky Fuel Injectors and/or alot of those symptoms remind me of how my car drove with a F'd up EGR valve.
Old May 10, 2007 | 11:35 AM
(Mid-Atlantic)
EGR valve is another very good posibility, there was a recall for it on the 3.0's greg
Old May 10, 2007 | 12:05 PM
gotguinness?'s Avatar
Does your gas pedal have to have an unusual amount of pressure pressing on the pedal to get the RPMs up??? Mine's been doing this lately...I know I have a Leak in my B-pipe, btu could this be a result of a bad EGR valve? Easy fix?
Old May 10, 2007 | 12:09 PM
artbran's Avatar
666 Speed
I just remembered that i still have the top intake manifold, and TB from when i parted my first gen... Soo thats always an option. Its got 52 miles on it as I painted my first one all silver with red accents and swapped it to the other first gen that i had. So if you want that, I can sell it to you.
Old May 10, 2007 | 03:57 PM
artbran's Avatar
666 Speed
^thats 52k miles
Old May 10, 2007 | 07:54 PM
legendaryCL98's Avatar
'07 November = STI
you guyz are lucky bastards.. we only have 92 over here..
I WANT 93!!
o.. and my
i think its either the alternator or something to do with your fuel.. does it sputter alot? maybe you need new plugs?
Old May 10, 2007 | 08:15 PM
dragon084's Avatar
1999 CL3.0
i hope that its only the plugs
or only the fuel filter.
or only something simple.
I installed a ground system today and it did nothing.
I'm at the point where I'm depressed over this shit.
I love my CL and this is really putting a damper on life.
^ the truth hurts.
I might bite the bullet and drop the car off at the Honda dealership tomorrow.
( i have an extended waranty )
Old May 11, 2007 | 12:55 AM
Danil ACE's Avatar
Sounders FC
87 here costs $3.43 per gallon I've seen it for $3.55 closer to seattle.
93 is 20 cents more per gallon, and most of my driving is stop and go (not too much freeway), so my gas mileage sucks anyways.
Old May 11, 2007 | 03:32 AM
'07 November = STI
dude!! we just hit 4 bucks today in the dirty parts of seattle for 92!! im going crazy!
Old May 11, 2007 | 08:28 AM
(Mid-Atlantic)
We're on that way too, hope that doesn't come here
Old May 11, 2007 | 11:03 AM
sumdumguy's Avatar
$3.11 for 87 here
Old May 11, 2007 | 12:21 PM
SupraManAG's Avatar
One custom CL
same here. $3.40 for 93 n my H22 wont run on anything but that.
I get my gas in NJ for about $.50 less per gallon.
As far as the problem my car has been acting up big time too. I need to clean my IAC plus seafoam. Oil job, air filter n clean spark plugs.
maybe a Tein SS-P next week
Old May 11, 2007 | 12:36 PM
zhouz's Avatar
say: zouts
last time that bogging thing happened to mine (sounds just like your problem) it was my ignition wires.
Old May 11, 2007 | 05:41 PM
dragon084's Avatar
1999 CL3.0
if these are spark plug wires, then where are the ignition wires?
Old May 12, 2007 | 10:31 AM
dragon084's Avatar
1999 CL3.0
anyone?
Old May 12, 2007 | 09:41 PM
zhouz's Avatar
say: zouts
yes yes, those are the ones i was referring to. yours look new-ish though...
Old May 15, 2007 | 06:49 AM
sumdumguy's Avatar
^ for the IAC, do I just get in there with a brush? that's just a sensor right? cuz I took it back to the dealer twice and they said it was a "loose" plug wire. I think that's bull but I don't wanna drive 20 min just to have them gimme the run around. but I can't stand this puttering.
pizokk1
Sep 17, 2015 09:29 AM
Billu99tl
Sep 13, 2015 11:30 AM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
