Engine light after h22a install
Old Mar 25, 2004 | 07:46 AM
97CLgenius's Avatar
Always drivin 100+
Ok, how did you guys with the h22a swap reset your engine light. My mechanic can not make out the codes because they are in ob2 when the motor is obd1 or something like that. Any how just wondering if there is a trick to reseting the light oh and i switched to a manual and wanna get rid of the parking light that stays on also. Do I just have to take that bulb out of the odometer, or is there a wire I can cut. Any advice would be grateful, thans fellas.
Lata
Paul
Old Mar 25, 2004 | 09:07 AM
97CLgenius's Avatar
Always drivin 100+
Come h22a owners looking for some advise
Old Mar 25, 2004 | 09:26 AM
SooDARK's Avatar
05' 350z 6spd.
yeah my check engine light just randomly comes on and off. they said it's because I no longer have the o2 censor in the cat. now it's somewhere near or in the header, but i think pulling the bulb mght be the only way. i have 2 other friends with swaps and theirs do the same thing.
Old Mar 25, 2004 | 10:29 AM
Mark Davison's Avatar
Big Block DOHC Type-R
OBD1 ecu's do not recognize the second o2 sensor. The code comes from the ecu. If your using an p13 look for the p13 codes and crossreference with your check engine light.
Old Mar 26, 2004 | 01:03 AM
turbotk's Avatar
get a p28 ecu with a hondata chip and PRESTO, GONE!
Thats what i did. Plus, you car will run hella better and stronger.
Feb 25, 2020 09:57 AM
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
whitesoxsfan12
Sep 7, 2015 04:07 PM
