Eibach 2 !!!!!
Old 06-27-2007 | 06:57 PM
WolfBoy's Avatar
Flamenco Blk 3.0CL PREM
Eibach 2 !!!!!
sorry for re-threading !! but my last thread was closed after not even 24 hours and didnt even say why ! and the last dude "maiyumi_chan" who said he had both prokits and teins's doesnt accept PM so i had to repost ! i searched in all relative threads and couldnt get a proper answer so .. i thought the tein's is more of a drop and not as comfortable as the prokits? i might have to go for the comfort as appose to looks so plz lemme know before this one is closed ! (why?)
ps i got kyb agx's from ebay this was the only one i found for the cl's so is this what fits the 3.0 ?!
tanx
Old 06-27-2007 | 07:04 PM
WolfBoy's Avatar
just called the acura dealer ship and i was told that the struts for the 97 2.2 is a totaly different design !!! so im not sure if that ebay link up there is accurate.
Old 06-27-2007 | 08:30 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
They're the same, you can get those
Old 06-28-2007 | 03:13 AM
maiyumi_chan's Avatar
tanx
^^ heehee im actually a girl, not a dude. LOL! but anywho, did you have a question? i'd be glad to help =) (i actually dont know why i cant accept PM's... maybe i have to past a posting amount i think.)
Old 06-28-2007 | 09:09 AM
(Mid-Atlantic)
YOu need to get past 20 posts
Old 06-28-2007 | 09:45 AM
saiko_cl_duck's Avatar
You couldn't find this info by searching?
It's been covered many times over.
The noob guide also specifies what ones fit what model.
Go with the teins if you want a lower drop, eibach if you want a little drop with a more stock feel.
Old 06-28-2007 | 09:59 AM
SwervinCL's Avatar
Nom Nom Nom Nom
Is large orange print on the first page not obvious enough?
https://acurazine.com/forums/showthread.php?t=179727
Read and enlighten yourself.
Old 06-28-2007 | 10:15 AM
732xghost's Avatar
eilbach sportlines or tein s-techs.
Old 06-28-2007 | 03:11 PM
ohh wow! i had better stop lurking and start posting!
Old 06-28-2007 | 03:17 PM
WolfBoy's Avatar
yeah well i found out about this but i also found out that eibach will not be an even drop front and back !! so although thats what i need .. a more comfortable ride but then i dont want the car to look all wierd ... ! thats the problem. teins are 2" drop right ?
Old 06-28-2007 | 03:20 PM
WolfBoy's Avatar
thax for enlightin me .. if u have a look u will see im not really a noob and that didnt help me .. it doesnt say what the hell to do when the eibach's will have my car sitting lower on the back !!!!
Old 06-28-2007 | 03:24 PM
WolfBoy's Avatar
im sorry .. my bad.
would u happen to have a picture of ur car with the teins and with the prokits ?
and how bad was the prokits at the back .. is it obvious that it sits lower ?
i guess the streets in hawaii are way better than ours over here and the teins are the right choice ! but im not sure about them over here ! tanx for the helo btw.
Old 06-28-2007 | 03:27 PM
WolfBoy's Avatar
hey dude .. the sportlines wont drag the back of the car like prokits ???
ps i guess they sit lower and stiffer than the prokits aswell right ?
Old 06-28-2007 | 03:30 PM
WolfBoy's Avatar
hey dude .. i called some other dealers and they all said that the 2.2's and 3.0's dont have the same shocks .. so what the hell !!???
im trippin over here casue i really cant afford experienceing diff stuff right now !
Old 06-28-2007 | 03:57 PM
(Mid-Atlantic)
They have different shocks for the different weights of the engine. The mounts and everything are the same. The KYB/AGX that you're looking at will fit either 2.X or 3.0 since you can adjust the stiffness to what works for your car. If I were you I'd get the tein S techs, they feel pretty soft too, especially with the KYB/AGX you can't go wrong with that combo.
Old 06-28-2007 | 05:10 PM
SwervinCL's Avatar
Nom Nom Nom Nom
Its not that the back sits lower. Its in optical illusion (im being serious). I have the Teins. The front fenders are cut higher, making you think that the back is sitting lower. My drop is pretty much flat, but I have more wheel gap in the front, than I do the rear.
All these pics are with the Teins.
http://www.acura-cl.com/forums/showthread.php?t=185645
Old 06-28-2007 | 05:23 PM
WolfBoy's Avatar
tanx buddy i appreciate the help.
Old 06-28-2007 | 06:12 PM
WolfBoy's Avatar
car looks great .. i think thats the setup i want .. although i have 225.45.17 'a on the car .. would i be better off with some adjustable camber kits or leave it the way it is ?
hvnt found anything for the v6's online nwayz !
Old 06-28-2007 | 06:41 PM
(Mid-Atlantic)
You def want adjustable camber kit, but you'll be alright with 17's don't sweat it. If you rub, just get 40 series tires
Old 06-28-2007 | 06:42 PM
(Mid-Atlantic)
The camber kits are universal, anything for a 94-97 accord will work, it's just ball joints and /or control arms
Old 06-28-2007 | 06:58 PM
DaInFaMMuS1's Avatar
eibach sportlines ftw...good drop and fairly good tight ride
Old 06-28-2007 | 07:08 PM
SwervinCL's Avatar
Nom Nom Nom Nom
If you look at the last pics with the rims, that is also the tire size that I have. That is also with the AGX's. You having a v-6, your front end will dip a little lower due to the weight of the engine. Which IMO will make your drop look a lot better than mine.... I have a camber kit. The ingalls one. Just in the front though. Nothing is needed on the rear.
EDIT: Im sure Justin (Klepto) will stick his nose in here telling you to slam it do the earf and tell you "negative camber FTW" with his camber kitless self...
Old 06-28-2007 | 07:31 PM
WolfBoy's Avatar
great help people .. i am buying all this stuff hopefully tonight . will post pics as soon as everything is done .. since we are on the upgrade subject what should i grab for my intake .. cold ? short ? ram ?
while im at it, i might aswell !
Old 06-28-2007 | 08:38 PM
WolfBoy's Avatar
what do u guys think of this kit ? ebay camber kit
Old 06-28-2007 | 11:25 PM
ZeroCL's Avatar
W WHIP.
Good luck with everything, so you're going with the S-Techs or what? How much are you paying for everything,
and a rule for ebay, non moving parts = yes, moving parts = no.
Old 06-28-2007 | 11:33 PM
(Mid-Atlantic)
I'd go SPC or Ingalls man, I went Ingalls front and rear. Hope you're happy with everything
Old 06-29-2007 | 02:18 AM
SwervinCL's Avatar
Nom Nom Nom Nom
Old 06-29-2007 | 06:23 PM
legendaryCL98's Avatar
'07 November = STI
wow! another girl! keke.. nice to meet ya heh
and on a another note... the suspension thing IS in the n00b guide.. i believe..
Old 06-29-2007 | 07:44 PM
SwervinCL's Avatar
Nom Nom Nom Nom
The suspension thing is in the noob quide, to an extent. The drop in inches is in there for many of the popular springs, which is what I thought he was asking for.
Old 06-30-2007 | 06:24 PM
HAHAHA! wow, i guess being a girl changes everything huh? haha just kidding. nice to meet you too. i can post pics of my car LOL!
Old 07-01-2007 | 01:37 AM
i3leusky's Avatar
hey i dont know what spring you gonna buy but i wouldnt recomend ibach it sitting three finger gap in the front and a little less then two in the back i use to have ibach on didnt like it lurk around forum and find out that neuspeed give me more drop without givin up ride quality so think about it man, plus neuspeed still didnt give me the low i need but thats good enough unless i want to go to tein coilover which is too much for an acura. and chan are you really a girl? can you pm me and prove this? hehehe jk welcome to the forum
Old 07-02-2007 | 02:50 AM
thanks for welcoming me guys but i think i posted too much in this thread and i didnt even contribute anything! LOL! sorry "wolfboy"! (and yes, i promise i am a girl).
Old 07-02-2007 | 12:29 PM
i3leusky's Avatar
i think a lot of the guys on this forum want to see picture of you and your car to see which one is sexier then the other...
Old 07-02-2007 | 11:09 PM
'07 November = STI
man.. speak for yourself .. keke..
i just wanna see pics of her.. LOL.. j/p
Old 07-03-2007 | 01:19 AM
ahhh come on guys! is it custom for the girls of acurazine to post pics of themselves? LOL jk!
although i really need to stop whoring up this thread!!!!! i'll make a new one and post pics.
(pics of the car that is. )
Old 07-03-2007 | 07:26 PM
krazy99cl's Avatar
O.G.
Hurry up with it too...Ill just add you on myspace for now. how about that? well hurry. and stop reading this post.
Old 07-04-2007 | 09:52 AM
WolfBoy's Avatar
haha u see .. something good came outa my thread . . and u guys go and block my last one ...
and maiyumi, u can do whatever u want with my thread or anything else mine !!! wink wink, nudge nudge ...
Old 07-04-2007 | 10:21 AM
(Mid-Atlantic)
Old 07-07-2007 | 01:45 PM
Dan3952's Avatar
This is covered elsewhere, but..
I have the Prokits and it's a fairly conservative choice.. 1.3 inches makes for a very streetable car but still a lot less suspension travel than stock, and you don't need a rear camber kit, they will need to adjust toe-in and that's it. 1.7 or 2.0 inches drop you will scrape your muffler a lot and it ends up looking like race car. For ultimate performance I will take the Tein SS or Koni Yellow. If it was 1.7 inches and you don't want coilovers I would take H&R Sport over Eibach Sportline
As for the difference in ride height front to rear, the gap is still different like it was before lowering I don't think it matters which kit unless the inches drop is listed as different front to rear
emailnatec
29
09-28-2018 04:27 PM
Onyxthecat
10-18-2016 02:05 PM
mmhdavid
ILX Tires, Wheels & Suspension
11-09-2015 11:18 PM
TSX 09
33
10-25-2015 01:32 AM
TSX 09
09-10-2015 10:21 AM
Quick Reply: Eibach 2 !!!!!
