Dropping
Dropping
Hey guys, I know this is most likely a repost and probably have been discussed many times before. But whats the difference between the Pro-kits and the Sportline Kits?
And since i'm still new to this..what would i need to do if i wanted to do either one of those? Would the springs be enough, or do I need something more?
My car is bone stock now..and i'm finally starting to think about doing some stuff to it. And do any of you have pictures w/ pro-kits or sportlines? Thanks a lot.
Prokit, lesser drop (1.5"), stiffer (less bounce), can use stock shocks for awhile.
Sportlines, slammed look, bounce, and will romp your stock shocks. Also, you will need front and rear camber kits.
Shock options, Koni yellow's (best, but expensive), KYB AGX's (Mid range, can go from stiff to stock with a simple turn, and tokico blues (ruff ryder's). There are others too like the KYB gr2's and more, can't think, but the above are the best.
I weighed the options, and a Prokit with AGX's was right for me. No camber kit needed and handling is all there. H&R and Neuspeed also make good springs, check them out as well. BTW, i have a prokit drop in my pics....
emailnatec
29
09-28-2018 05:27 PM
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
08-16-2016 03:49 PM
us285126
10-02-2015 03:03 PM
4drviper
09-23-2015 08:42 PM
