draining trans
Old Feb 21, 2004 | 10:00 AM
JetBlackAcuraCl's Avatar
Promiscious Boy
draining trans
can anyone list the steps and some advice to draining trans fluid...and putting in new fluid...also a new trans gasket? im planning on doing it myself later in the day.
Old Feb 21, 2004 | 12:20 PM
wilp99's Avatar
should juse be a drain plug at the bottom of the tranny, remove the drain plug and the upper plug, which is on top of the tranny. it all drains out then u fill it back up, with ONLY honda fluid, NOT dextron 3. dextron is only a temporary replacement, and prolonged use will eat the seals out of your tranny, good luck.
Old Feb 21, 2004 | 12:21 PM
wilp99's Avatar
the filter you cannot get to without cracking open the tranny. which isnt a good idea. the filter only gets changed when theres a tranny overhaul.
Old Feb 21, 2004 | 09:12 PM
Promiscious Boy
ohh word...i also got a gasket...should i be replacing the existing gasket with the new one?
Old Feb 21, 2004 | 09:58 PM
wilp99's Avatar
naw man theres nothin to do. just drain it and fill it back up. if the gasket is leaking u need the dealer to change it, cause if u open it up the bands will fall and u will be out a tranny if u dont know how to put it back togather. good luck. remember u must use honda atf fluid.
Old Feb 22, 2004 | 12:50 AM
suXor's Avatar
Still trolling
um, there is no filter guys.....
Old Feb 22, 2004 | 12:53 AM
suXor's Avatar
Still trolling
Just drain, fill, run it around town for 10-15 minutes (stop and go driving so that the car shifts), drain, fill, etc.... Do this until you have refilled at least 3 times. I buy a case of the Honda ATF (MTF for you manual boys), and I end up with 2-3 bottles left.
Old Feb 22, 2004 | 03:45 AM
CL-zero's Avatar
it's good idea to heat up the oil with hot water.
the oil is thick and it will make it little bit smoother.
Old Feb 26, 2004 | 09:18 AM
damond's Avatar
You're gonna need a pretty long funnel also.
You'll need to remove the air box (3.0) and the refill bolt is gonna be TIGHT, as well as the drain plug.
Old Feb 26, 2004 | 10:19 AM
tightac1's Avatar
GOT AIR PPPPSSSSSSTTT?
Can you get the honda fluid anywhere beside the dealer
MetalGearTypeS
Aug 29, 2016 08:28 PM
LeVeL
Oct 18, 2015 04:19 PM
hpfiend
Sep 27, 2015 06:59 AM
Rcelestino93
Sep 23, 2015 10:01 PM
STL TL-S
Sep 23, 2015 08:52 PM
