distributor removal
Old Nov 1, 2006 | 09:12 PM
rustyskim7's Avatar
distributor removal
has anyone on here removed there own distributor before? anything i should look for. my o'ring went bad so i'm going to go ahead and replace it as well as the valve cover gasket. is it possible to remove the distributor myself? thanks.
Old Nov 1, 2006 | 09:54 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
I've seen it done, never did it myself. The CL's looks pretty straight forward, wires are just plug and play
Old Nov 1, 2006 | 10:46 PM
Sleep_DEPRIVED_Sleeper's Avatar
Turtle Charged, Biotcch!!
Old Nov 2, 2006 | 06:19 AM
TexasHonda's Avatar
A potential problem that vexed me while working on my old Accord EX is the distributor drive key that engages the camshaft slot. The key appears symmetrical at a glance but is slighltly wider on one side. It will only go in one way. Don't try to force it in the wrong way and damage the distributor.
Looking at the drive key slot in the camshaft it is hard to determine which is the wider end. If you mark the position of the distributor rotor relative to the distributor cover when you remove it will simplify installation.
Replace the distibutor Oring w/ a new ring from Honda. They get old and brittle, causing an annoying oil leak from the distributor.
good luck
Old Nov 2, 2006 | 06:37 AM
rustyskim7's Avatar
thanks alot guys i'm going to attempt it on saturday. one of my friends has done it already and he told me the same thing about it going in one way. i just wanted to make sure. thanks alot.
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
dainmezron
Oct 16, 2015 06:56 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
lowgrowl
Sep 26, 2015 05:18 PM
