dip stick keeps popping out?
where is....
i noticed my dipstick keeps popping out and little bits of oil comes out after driving.
i dont think the dipstick is the problem either.
any ideas?
any ideas?
where is....
its normal, the shape of it hasnt changed since i bought the car 6 months ago, it only started when i started driving on the highway acouple weeks ago
contrarian in fashion
Originally Posted by AznX TL
yep, its tight as it normally is. im thinking too much pressure somewhere is making it pop up
I think your PCV system is blocked, which would cause crankcase pressure to build. Crankcase pressure would bleed into air intake when pressure was enough. It could also cause your oil dipstick to push up. Clean or replace PCV and make sure PCV hose and air intake to valve cover hose is also clear.
good luck
good luck
where is....
good luck
good luck
A motor w/ poor compression rings would have large amount of gases bypassing the rings increasing crankcase pressure, and possibly overwhelming the PCV system causing positive pressure when engine vacuum is low (acceleration). I had a 90 Bronco which pushed oil back into the air intake because of this, but did not push the dipstick out.
PCV should be cleaned by blowing/flushing the hoses w/ mineral spirits or gasoline to clean any blockages. A new or cleaned PCV valve completes cleaning.
good luck
good luck
Originally Posted by Cocoa
My dip stick likes to pop out from time to time and shoot a little something out as well.
Acura604
2G RDX Photograph Gallery
17
02-08-2021 03:32 PM
Joe Avesyan
09-29-2015 03:57 PM
