Debadging
Old Jun 3, 2002 | 10:38 AM
STLUSMCH's Avatar
kept the beast
Debadging
I GOT THE ACURA AND THE 2.2CL MARKER OFF BUT THAT ADHESIVE TAPE IS STILL ON AND A BITCH TO GETT OFF WHATS THE BEST AND FASTEST WAY TO GET THIS DONE
Old Jun 3, 2002 | 10:40 AM
d98clturbo's Avatar
Old Timer
use deisel and a soft cloth
Old Jun 3, 2002 | 10:49 AM
STLUSMCH's Avatar
kept the beast
WELL IM A LIL LOW ON DIESEL WILL ANYTHING ELSE WORK NO DIESEL FUEL AT MY HOUSE
Old Jun 3, 2002 | 10:58 AM
hornyleprechaun's Avatar
Bent = #1
Try goof off...or goo off..whatever that stuff is called...worked so easy...bout $2-3 a bottle...thats what i used..
CL'S
Old Jun 3, 2002 | 11:00 AM
STLUSMCH's Avatar
kept the beast
SO I CAN GO PICK IT UP AT A AUTO PARTS STORE
Old Jun 3, 2002 | 11:03 AM
AtlCl's Avatar
Not AtlCl98 or Atl-CL
I have a great idea:
Have your Caps lock button fixed and start typing normally.
Old Jun 3, 2002 | 11:07 AM
STLUSMCH's Avatar
kept the beast
Hey atlcl are u happy now im so sorry i offended you
Old Jun 3, 2002 | 11:26 AM
23's Avatar
23
Use goo gone and then buff it out with 3M scratch remover for dark cars and you will never be able to tell something was there.
Old Jun 3, 2002 | 11:32 AM
Bent = #1
23: do you know how much that 3M stuff costs?..thanks
CL'S
Old Jun 3, 2002 | 12:08 PM
Nugs3's Avatar
I boiled some hot ass water in a tea pot and poured it on the gunk rubbing it with a towel. pour rub, pour rub, pour rub. gotta use your finger nail too-- lightly Then i got what was left (very little) with the bug remover.
Old Jun 3, 2002 | 12:58 PM
CO30CL's Avatar
Here's a better question: What inspired you to remove the badges in the first place? Are you ashamed to own an Acura and don't want others to know what it is?
Old Jun 3, 2002 | 01:18 PM
KingsFanPaul1's Avatar
2002 NBA Champs!!!
i did something similiar and i fucked my shit up got all kinds of scratches and crap and you ca see where it used to say 3.0cl and because i forgot the trunk had been recently repainted i ended up chipping a couple peices of paint off and tried to use some touch up to fix it and man was that a bad idea. :o
its ok now the trunk matches the rest of my car, crappy ass paint job. i am almost ashamed to go to the bay area meet because i dont want other cl owners to see it:o
Old Jun 3, 2002 | 01:45 PM
moforose3.0's Avatar
What can I get ya?
Re: Debadging
Just a little note for the future, it helps to use exclamation/lower case letters. It makes it a little easier to understand.
Old Jun 3, 2002 | 02:31 PM
Bent = #1
The reason I did it was because I like the cleaner look of my trunk...I also changed the silver Acura symbol to the blue symbol...I am not ashamed of my CL...I love my CL..
CL'S
Old Jun 3, 2002 | 02:50 PM
d98clturbo's Avatar
Old Timer
diesel is the cheapest and works the best.. there is no need to go and buy 3 or 4 different things just to take off some goo....it took me about 3minutes to take mine off and you cant tell that there were badges there it is clean....diesel is a few cents....probably 50 cents to fill a spray bottle...you cant beat that
Old Jun 3, 2002 | 03:27 PM
krazyplaya213's Avatar
the name says it all
debadging...
well the easiest way is using a blowdryer to get it hot then rub it with some alchohol..... comes right off!!!!!
Old Jun 3, 2002 | 03:29 PM
Nugs3's Avatar
Re: debadging...
Or boil some water
heat is key!
Old Jun 3, 2002 | 09:33 PM
STLUSMCH's Avatar
kept the beast
I got it off but u can still tell whee it is and its not sticky just smooth so i guess ill try the diesel fuel tomorrow
Old Jun 3, 2002 | 09:48 PM
Ricka220's Avatar
Not Fast But Built 2 Last
fuel solvent
If no kero, charcoal lighter fluid works just as good and is benign to factory paint.
Old Jun 3, 2002 | 11:36 PM
Blacura's Avatar
-iii-(
mine were a bitch too, and i did it in the middle of winter. got so damn frustrated :angry: i ended up using alcohol and some WD-40 then polishing compound and rubbing compound. turned out pretty well, but there is some ghosting but not enough to see it in my pics (in my sig). How much is that 3M stuff? Maybe that will help w/the ghosts.
Old Jun 4, 2002 | 12:28 AM
23's Avatar
23
Heat them up wiht a blow dryer then use fishing line behind them and they come off fairly clean. By the way the 3M scratch remover cost $8 a bottle but it works wonders on swirls and scratches. Well worth it
Old Jun 4, 2002 | 09:04 AM
AtlCl's Avatar
TLDude876
Dec 28, 2016 03:18 PM
jmaxima03
Sep 27, 2015 10:22 AM
HOWELLiNC
3G TL Photograph Gallery
Sep 17, 2015 10:04 PM
buhhbuhh
Jul 27, 2007 09:58 AM
