D4 doesnt light up after work on cluster
Old Nov 29, 2008 | 02:44 PM
YL Al's Avatar
1997 acura CL 3.0
hey guys so i opened up the whole cluster assembly and messed around with it, for educational purposes, i took the plexi glass off and took each section off as well ,ie,the fuel gauge,speedo,the rpm gauge,and the temp. gauge. then i put them back togther and reversed the whole process till everything was back in place.
i test drove the vehicle, and everything started working like it should except the D4 light.
when i engage p,r,n,d3,d2,d1 they all light up except D4
im assuming i somehow blew the light for D4 when i was moving parts around.
any other reasons you can think of?
Old Nov 29, 2008 | 02:50 PM
DoubleSh0t's Avatar
Well, if it worked before you opened up the cluster and it didn't after you opened it up, I'd say it has something to do with you opening up the cluster
Nah, but you'll probably have to pull out the cluster again and make sure the bulb hasn't come loose. I don't remember if those bulbs are soldered in or not.
Old Nov 29, 2008 | 03:03 PM
YL Al's Avatar
i believe they are soldered in,i didnt pay close attention to those gear lights but can anyone else give me any tips.
heres wat i know: it doesnt work because i opened up the cluster
heres wat else i know: im not about to open it again without knowing the problem. its a pain in the ass and its freezing outside.
Old Nov 29, 2008 | 09:51 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
They're bulbs they're not soldered in
Old Nov 29, 2008 | 10:47 PM
swoleCL's Avatar
¿baCon?
Old Dec 1, 2008 | 05:14 PM
purple3.0haze's Avatar
they are however stuck in some plastic/rubber holder that doesn't come out i broke my R and D4 blubs trying to get them out.
Old Dec 1, 2008 | 05:56 PM
MoSp33d's Avatar
N00berator
it means an error has been detected by the TCM (trans control mod). You need to retrieve the DTC to find out what is causing it. Diagnostic trouble codes (or fault codes) are codes that are stored by the on-board computer diagnostic system. These are stored in response to a problem found in the car by the system. or maybe its a faulty alternator?
Old Dec 1, 2008 | 09:02 PM
YL Al's Avatar
buddi,i could see that happening,but this issue came up as a result of me taking apart the cluster.there shouldnt be any trouble codes stored.
so i think i broke the bulb?
Old Dec 2, 2008 | 07:05 AM
Mach30SiR's Avatar
Bagel Bomber
Open it back up, and swap the D4 light with a known working light, d3 ect.... that will narrow down the bulb problem.
Old Dec 2, 2008 | 07:18 AM
YL Al's Avatar
aye aye captain
mada51589
Jan 9, 2025 04:40 PM
HairyMonkey019
Apr 22, 2016 10:50 PM
wusty23jd
Sep 24, 2015 11:41 AM
acurajj
Sep 19, 2015 03:47 PM
drewdeezy03
Sep 3, 2015 08:04 PM
