D4 and check engine
Old Dec 8, 2004 | 09:12 PM
fusionnv's Avatar
Gimmie my points Biatch!
D4 and check engine
Well after getting the starter replaced, my check engine light came on. But I just noticed that I have a blink D4. I did some searches and it does not look good. My car so far is running fine and I doesn't feel like it is slipping at all. Anybody know if there is a chart for the tranny sensors etc. I did a search and I couldn't find it. Thanks.
Old Dec 8, 2004 | 09:21 PM
shineynitelite's Avatar
NAWWWWSSSSSS
what other option do you have except getting the code read.. next time the lights on get a diagnostic done
Old Dec 8, 2004 | 09:24 PM
fusionnv's Avatar
The check engine light is stays on. But the D4 does not flash. I tried the paper clip trick and it gives these codes:
The check engine light gives: 78
The D4 light flashes: 25, 7, 16
I tried reseting the ecu by pulling the fuse but it doesn't seem to clear it out.
Old Dec 8, 2004 | 09:59 PM
ne0's Avatar
ne0
ariseMedia/RonJon Collabo
Your tranny is going to take a shit on you any second...gl with that though.
Old Dec 9, 2004 | 08:59 PM
legendaryCL98's Avatar
'07 November = STI
if the D4 is blinking, it usually means your speed sensor needs to be replaced.
most likely while your traveling on the freeway, the speedo reads 60 then drops down to 0 and back up to 100 and back down to 0 and so on and so on..
try replacing the speed sensor before assuming its your tranny
Old Dec 9, 2004 | 09:44 PM
fusionnv's Avatar
Well so far, it does do any of that. I think this weekend I going to try to disconnect the battery and then reconnect it instead of pulling out the ECU fuse. It been raining like a bitch so I don't want to do this in the rain. Hopefully tom it be nice. but in the mean time i been searching around for a tranny. I emailed dr evil just curious wat a tranny would cost from them. Here are the prices:
Street Evil $2110.00
Reprogrammed valve body, New OEM solenoids, Upgraded clutches, Stock Converter
Pure Evil $2650.00
Reprogrammed valve body, New OEM solenoids, Upgraded clutches, HD converter.
Max Evil $4000.00
Reprogrammed valve body, New OEM solenoids, Raybestos Blue Plate Racing Clutches, HD converter, LSD differential
Core deposit is $500.00
Roundtrip freight $240.00
We remanufacture while other companies rebuild.
* Remanufacture - To manufacture into a new product.
* Rebuild - To make extensive repairs to.
This is for our car on the 2.3 model. Looks like i have an option to rebuilding it, which i see from post that it can range from 1800-2500. So it gonna be the cost up there plus install cost.
Old Dec 10, 2004 | 07:58 AM
wilp99's Avatar
no no no no make sure they grounded the wires they removed when they changed the starter. it will be a big ass loop with bout 5-6 wires attatched to it. it is supposed to be grounded to the block. if not most of the sensors will not work right. also make sure none of the other sensors are disconnected or maybee u smashed the connector. oh yea its pretty cold here in turkey. and wil is still a cool ass dude. that is all.
Old Dec 12, 2004 | 01:43 AM
fusionnv's Avatar
Ok new update. I cleaned off the wires and took off the battery this time. So far after 100 miles of driving I have no more check engine light. Thanks god. But it seems like I am in the clear till the next repair. But this little scare made me check how much a dr evil tranny is for the 2.3. I think i put that in the to do like if I decide to do a h22 swap. It would be a nice combo, dr evil tranny and then h22 or maybe even turbo if i keep the car long enough.
Yikes
May 3, 2021 04:29 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
Billu99tl
Sep 13, 2015 11:30 AM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
