Conversion Harness for Swap...
Ok, I am trying to buy a conversion harness so that my mechanic can complete the swap. I have a 97 2.2 Acura CL and I recently bought a JDM F22B1 94-97 Motor. I am not sure if I need the OBD2-OBD1B or OBD2-OBD1A... if anyone knows please post.
Bump!
![what](https://acurazine.com/forums/images/smilies/what.gif)
i like acura
yes that harness is the one that you need. i assume your running the obd1 ecu? which probably came with the swap. you will need this harness to connect your new obd1 harness to your car which is obd 2. help at all?
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Bingo, my question as well, what ecu are you running?
Umm, actually i thought the ecu was what the car had in it.... I dont know much about cars. I guess its an obd1 ecu if the engine is obd1 but my car is obd2.
The whole problem was that my car would try to read for a crankshaft sensor that wasnt in the same spot on the new motor which imo is the obd1... and the sensor is in the distributor
this is the exacct engine I ordered maybe it didnt come with an ecu.
I hope it did because that would suck considering I am almost out of money... http://www.jdmtigerjapanese.com/details.php?id=1581
(Mid-Atlantic)
(Mid-Atlantic)
If it didn't come with an ecu, then your car has the obd2 ecu
Any way you can just extend the wires from the crank position center, and not have to worry about the wiring harnesses or ecu's?
so, since my car has the obd2 ecu, and the engine is obd1 i need the harness. i dont think the mechanic is going to extend the wires and wat not, so im just going to get the harness. im just confused on which one to get and dont want to waste any money
see I'm thinking i might need this one http://rywire.com/store/obd1-obd2a-c...ba24152bfd7289
Definite Answer
Ok, this is the last thread I will start on this topic. I need to order my harness tonight but I still do not know the harness I need. For a OBD2A ECU and an OBD1 engine, I will need this harness.... http://www.boomslang.us/obd1to2.htm correct?
(Mid-Atlantic)
(Mid-Atlantic)
Threads merged, you don't need 3-4 different threads
(Mid-Atlantic)
(Mid-Atlantic)
I understand, I'm just trying to keep all your info together
xsilverhawkx
09-28-2015 06:51 PM
