Got it back!
Old Nov 17, 2009 | 05:12 PM
gr8dale72's Avatar
Got it back!
This morning soon after I ordered the harness my mechanic called me, but I was in class and missed the call. When I returned the call he said I could pick my car up later that day and I didnt need the harness... He changed the timing cover from my old motor onto the new one. All is well except the gas peddle seems to hard to push, when I pushed it down hard it made a screaming noise.
Old Nov 17, 2009 | 05:35 PM
DaInFaMMuS1's Avatar
Made a screaming noise at WOT? Hmm...i don't like the sound of that.
Old Nov 17, 2009 | 09:24 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Sounds like he needs to adjust the throttle
Old Nov 17, 2009 | 09:46 PM
gr8dale72's Avatar
I was thinking something like that, would it be an easy job to do myself?
Old Nov 17, 2009 | 10:35 PM
dm8701's Avatar
of course. theres 2 cables on your throttle linkage. 1 is your accelerator , and the other is your cruise control. all you have 2 do is loosen the nuts up on the accelerator and then adjust them 2 wats comfy for you then tighten them up. shouldnt take you no more than 3mins
Old Nov 18, 2009 | 06:40 AM
Tehvine's Avatar
6spd FTW
Did the motor make a screaming noise or the throttle?
Old Nov 18, 2009 | 08:19 AM
gr8dale72's Avatar
the motor?
Old Nov 18, 2009 | 11:08 AM
bgsrmyth's Avatar
Screaming noise like you are describing usually indicate a worn or loose belt. Did you put new belts on the power steering and ac when the swap was done?
Old Nov 18, 2009 | 12:28 PM
(Mid-Atlantic)
Sounds like the motor which could be a belt like bg said, adjusting the throttle cable would help the mushiness of the peddle
Old Nov 18, 2009 | 12:30 PM
gr8dale72's Avatar
Nope, just new engine mount, timing cover gasket,oil& filter, and radiator cap....
but IDK maybe it was just because it hadnt been ran today its great. I can only drive it around my block though because I turned in my license plate to avoid flags. however, im going get it back tomorrow. and hopefully gonna get a new headunit. mine was swiped.
Old Nov 18, 2009 | 01:54 PM
(Mid-Atlantic)
no more screaming/whining noise? That's great, but I'd be wary of it coming back.
Your hu got swiped while it was at the shop?
Old Nov 18, 2009 | 02:20 PM
gr8dale72's Avatar
haha, i wish. then id know where to get it back from. no it got jacked a while back because my car was unlocked.
Old Nov 18, 2009 | 02:35 PM
(Mid-Atlantic)
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
d.lim
Sep 15, 2015 08:54 PM
