Code P0171 System too lean?
Old Nov 19, 2010 | 11:22 AM
shocker's Avatar
Hi guys I did a quick search on this and it sounds like one of the possible culprits is the primary o2 sensor. Where is this located on my 2.3 CL?
What are the other (most likely) causes? Should I be replacing the o2 sensor first?
Gas mileage seems ok...
Thoughts?
Old Nov 19, 2010 | 12:00 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
There are 2 o2 sensors, one on the cat, and one on the header
Old Nov 19, 2010 | 12:12 PM
shocker's Avatar
Thanks Ack.... Is there any way to tell which one is more likely to be throwing this code?
Seeing that my gas mileage is ok, could it still be an o2 sensor issue?
Old Nov 19, 2010 | 01:25 PM
(Mid-Atlantic)
Easiest way is to pull the code from an OBD II reader, most auto parts stores should do this for you for free, I know autozone does. If not, you can use a paper clip to get the code to flash, there's a green 2 pin connecter under the glove box that you use to get the code to flash and then look up the code here.
https://acurazine.com/forums/1g-cl-1997-1999-56/%2A%2A%2Anoob-guide-read-first-before-posting%2A%2A%2A-478508/
Here's another description on how to do it
Originally Posted by SupraManAG
take a little wire. splice both ends. under the dash below the glove compartment you will find a green connector plugged. unplug the connector from the stay. place the spliced wire in. each end in each hole. turn key to 2nd position. you will get a series of short and long blinks. long blinks = 10s and short blinks = 1s. so if you get three long and two short you have 32. after you get the code google honda cel codes. by the way you are running OBD2.
Old Nov 19, 2010 | 01:26 PM
(Mid-Atlantic)
Here's some more info about the o2 sensors also
Originally Posted by Nakamichi
Assuming O2 sensor is at fault, it's #28 in the pic below.
It's a sensor that should be at the end of the catalytic converter. Kinda like the following:
You'll need a o2 sensor socket to replace it.
It's a simple unplug connector, unscrew sensor, apply anti-seize to new sensor threads, then screw in sensor, plug in connector. Reset CEL and complete 3 drive cycles.
https://acurazine.com/forums/showthr...ght=paper+clip
Old Nov 19, 2010 | 02:12 PM
shocker's Avatar
Thanks.
I've already pulled the code (P0171). Cleared it once and it shows up again about 3 weeks later.
Question is, instead of replacing both o2 sensors, can I assume it's the one near the CAT?
Old Nov 19, 2010 | 02:15 PM
(Mid-Atlantic)
The code usually tells you which bank the o2 sensors are in
Old Nov 19, 2010 | 02:52 PM
shocker's Avatar
According to http://repairpal.com/OBD-II-Code-P0171-and-P0174
P0171 is bank 1. Would this be the sensor near the CAT?
Old Nov 20, 2010 | 12:37 PM
97'CL2.2's Avatar
i believe bank two is the one off the cat...bank one is further upstream
Old Nov 20, 2010 | 09:12 PM
(Mid-Atlantic)
yeah i think that would be bank 2
Old Nov 21, 2010 | 01:14 PM
shocker's Avatar
Alright... Thanks guys.
So I went ahead and ordered the OEM "front" sensor for $100 and change. Where is that one located?
Old Nov 21, 2010 | 09:01 PM
(Mid-Atlantic)
If you get under the car, should be around where the header meets the cat
Old Nov 23, 2010 | 03:31 PM
cwindsor's Avatar
Just a thought.... Running to lean on some cars could be a vaccum leak...
Old Jan 26, 2011 | 10:47 PM
pmendoza502's Avatar
check the vacuum leak first as it is a much cheaper and easier fix...
check for plugged Fuel Filter or weak Fuel Pump or Plugged or dirty Fuel Injectors
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
heykosal
1G RDX Problems & Fixes
Sep 21, 2015 09:41 AM
