clutch squeak
Old Jan 15, 2003 | 01:04 PM
98CLguy's Avatar
Speed is a necessity.
clutch squeak
i have this nasty sounding squeak when i push in the clutch. its not the pedal. any ideas on what it is and what i can do about it?
Old Jan 15, 2003 | 04:16 PM
niedejb's Avatar
Swaps? $3000 for 50HP? :(
Its either the pivot at the slave cylinder or the throwout bearing.
The slave cylinder can be greased easily, the t/o bearing has to have the tranny pulled.
Does it squeak with the engine off? If yes its not the t/o bearing.
Old Jan 16, 2003 | 03:32 PM
98CLguy's Avatar
yeah it still does it with the engine off. So how do i go about greasing the slave cyl? Is there a fitting on the pivot or do i have to remove something?
Old Jan 16, 2003 | 04:56 PM
niedejb's Avatar
The black guy hanging off the front of the tranny (just above the seat on the stool) should unbolt with just the two bolts. That line is flexible enough to just move the slave back away from the clutch fork and grease.
It may have some pressure on it but you should be able to unbolt and rebolt it without opening up that hydraulic line.
Youre on your own as far as what kind of grease to use...I have no idea.
Old Jan 20, 2003 | 11:05 AM
98CLguy's Avatar
thanks hopefully thats my problem. i'll call honda to see what they say to use. thanks again.
Old Jan 20, 2003 | 11:16 AM
MaCe's Avatar
fellow MASShole
my shit squeaked real bad ... i sprayed the hell outta the part that moves near the front of the engine ... didnt stop right away but its not doin it anymore
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
knight rider
Mar 4, 2016 08:59 AM
MilanoRedDashR
Sep 24, 2015 11:04 PM
