Clutch Problem...HELP!!!
Old Aug 14, 2007 | 02:06 PM
Racer510dude's Avatar
I just got my exedy clutch/fandanza flywheel installed last weekend and got into some trouble. When i press in the clutch pedal the pedal wouldn't release (its stuck). This shit scares me because I'm stuck in gear and have to release the clutch by using my feet to lift the pedal back out. Anyone know what may cause this? I think its the clutch slave cylinder...
Old Aug 14, 2007 | 02:23 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
A lot of manual drivers have problems with their slave cylinder. Check it for leaks or cracks. Especially if that's what you suspect, and it's a cheap easy fix.
Old Aug 14, 2007 | 03:55 PM
civic_slayer's Avatar
probably your master cylinder but while your at it you might as well get a rebuild kit for your slave cylinder
Old Aug 18, 2007 | 01:00 AM
found a leak at the master cylinder...needs to be replaced...
Old Aug 18, 2007 | 01:48 AM
lnsyone's Avatar
CL 4 LYFE
mean
Old Aug 18, 2007 | 10:42 AM
The master is a little trickier to replace but it is not that bad. Enjoy the new clutch/flywheel I know I do.
Old Aug 22, 2007 | 01:08 AM
Im experiencing some major difficulty installing the master cylinder...I replaced the master cylinder with a new one but couldn't get any pressure on the pedal. PLZ help...my car is down until i fix this...There are no leaks what so ever.
Old Aug 22, 2007 | 01:16 AM
did you bleed the clutch?
Old Aug 22, 2007 | 05:14 PM
no i didn't have a bleeder at the time and my slave is all clog up...going to bleed it today and replace the slave cylinder as well so hope all is good after that.
Old Aug 22, 2007 | 07:53 PM
well that is your problem you have air in the lines. you have to bleed it or else it wont work.
Old Aug 22, 2007 | 08:54 PM
SupraManAG's Avatar
One custom CL
have someone help you. open fluid canister open. bleed the fluid thru the slave cylinder. put fluid in canister. bleed again. do this 3 or 4 times. if your clutch feels kinda slugish at first just drive it it will get better. have fun
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
knight rider
Mar 4, 2016 08:59 AM
MilanoRedDashR
Sep 24, 2015 11:04 PM
