climate control LED swap
I know this has been talked about before and ive read almost every thread there is on this subject, but i still have a few questions because some of the threads contradict themselves.
I have a 97 3.0, and its my understanding that the instrument cluster requires a simple switch of #4 168/194 LEDs and #1 74 LED, also for the dimmer, cruise, and moonroof take a #74 LED but they have to be soldered with a resistor.
Now in terms of the lights on the climate control; climate control buttons need #74 LEDs soldered with a resistor, but can the climate display be done with the dasani water bottle like i did my clock. If not i will just have to solder and throw on a resistor.
just wanted to clear that up before i rip apart my whole dash. also any tips of taking off my woodgrain without snappin it.
thanx boiis
thanx boiis
For the wood grain, use this
https://acurazine.com/forums/showthread.php?t=171824
For the climate control, I've wondered the same because I want to do LED's in mine, maybe you can post some pics once u get it open.
Im not really a write up kinda guy, but i through some pics up
I would still like to know if i have to solder the climate lights or can i use a film to mask the green
noone knows???
yea you can use a film to change the climate control to blue. but if your goin for other colors it prolly won't work. for the film i used some stuff that they use for stage lighting i forgot what it was called. but it works pretty well.
Light gels work well. I have some blue sitting around that I intend to start using up.
Originally Posted by DoubleSh0t
Light gels work well. I have some blue sitting around that I intend to start using up.another question, theres 2 lights on top of the instrument cluster, what size bulbs are they. they werent mentioned in the DIY
Originally Posted by NACIREMA_DREAM
how do the light gels work and were can i get them
Light gels are just film that are used on theatre lighting - they're thicker (because of the heat) and are available in a wide array of colors. It's not really necessary for this job, but they work well. I got them from scrap on the stage that I work on.
the blue paper from the dasani water bottle wouldnt work???
I think the climate control is probably flat LED's the same that is used in the steering wheel key hole, which by the way, is a bitch to do, but worth it.
https://acurazine.com/forums/showthread.php?t=181564
I haven't found the time to pick up where i left off, but maybe someday.
navtool.com
31
Nov 16, 2015 08:30 PM
joflewbyu2
Oct 8, 2015 11:16 AM
navtool.com
Sep 25, 2015 05:15 PM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
