checking codes for the check engine light
Old Aug 31, 2003 | 05:13 AM
whittles's Avatar
I have read about the paperclip method but don't exactly know were to do this and how. Could someone point me in the right direction? I have a 99 2.3cl.
Old Aug 31, 2003 | 09:49 AM
LCARUCA 97's Avatar
Trailblazer = SUCK
the connector is right under the dash on the far right hand side.
Take out your glove box (three screws and one clip) and you will have no problem seeing it. The connector is blue with two wires.
Old Aug 31, 2003 | 11:40 AM
xerothermic's Avatar
can someone go into a bit more detail on this? my check engine light came on last night while i was on my way home...it used to be on when i first got the car, but no one knew why it was on, but then eventually it just turned off...until last night. so what exactly does the paperclip method do? and can i do it on my 97 3.0?
Old Aug 31, 2003 | 11:58 AM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
hey man i can walk you through it step by step if you want i have detailed instruction but you need to hit me up on aol im at jgiguere17
note: you do not need to take out the glove box, if you ly down look under your dash you can see the harness and you just unhook it and then "jumper the two wires with a paperclip and there ya go. but hit me up if you need more help
aol im: jgiguere17
Old Aug 31, 2003 | 06:26 PM
whittles's Avatar
after you jump out the switch what do you look for?
Old Aug 31, 2003 | 07:18 PM
LCARUCA 97's Avatar
Trailblazer = SUCK
jumper the connector, turn the key to on(don't start it)and watch the Check engine light. It will blink long codes for tens and short codes for ones. (i.e. 1 long blink followed by 5 short blinks = 15)
Old Sep 1, 2003 | 05:28 AM
whittles's Avatar
I got the code and it is 22 but I can't find what the code is. Any help appreciated. Thanks 97acuar3.0cl and lcarca97 for helping how to the the code.
Old Sep 1, 2003 | 05:33 AM
whittles's Avatar
I found a thread that stated it was a problem with the vtec. I guess this one goes to the shop.
mada51589
Jan 9, 2025 04:40 PM
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
