CHECK ENGINE LIGHT help
Old Jun 1, 2003 | 12:48 AM
KitsJAG5254's Avatar
1SlowCL
sup guys.. well yesterday before I put my CL to the car show.. I cleaned it and cleaned the engine bay.. but forgot to cover the distributor and intake.. when I left they weren't dry enough and when it reached around 3 or 4 RPM it seems that my engine was having a hard time and hearing sounds from it.. water!!!.. anyways... now it is back to its perfect condition because the water has dried out but my CHECK ENGINE LIGHT is on and won't turn off.. is there something I need to do to get this light off? Is it true that Auto Zone or Advance Auto Parts have a Check Engine LIght tester? Is it free or there's a charge for it? your help will be appreciated..
Old Jun 1, 2003 | 02:05 AM
Jawo's Avatar
Try to reset the chip by removing the negative battery terminal. Replace it after a few minutes. Hopefully, this will get rid of this problem.
I hope this helps.
Old Jun 1, 2003 | 04:29 AM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
check the check engine light code with the paperclip technique by neidjeb
heres your link..........http://home.insightbb.com/~niedejb/refs2.html
let me know if you need more help aol im = jgiguere17
Old Jun 1, 2003 | 09:06 AM
1SlowCL
thanks
sup guys.. appreciate all the help.. hope this works.. i'll let you all know.. thanks guys a lot
Old Jun 2, 2003 | 02:21 AM
TeamBlurryCL's Avatar
TEAM BLUR So. CAL
there a light green plug underneath the glove box. then you take a wire and plug it in to the two holes in the connector, looping the wire in a U. turn the car on to standby. the check engine light will start blinking. a long blink = 10 a short blink=1. the code will repeat until the wire is taken out. if there is more than one code, it will follow the first code. once the pattern repeats it's self then you'll know what to check on the check engine chart. good luck
Old Jun 2, 2003 | 02:36 AM
Wheres Got Rice...........Blurry, i thought my tage was long, yours beats out mine
Old Jun 2, 2003 | 10:10 PM
1SlowCL
thanks thanks..
sup teamblurryCL.. appreciate all the help.. I did get the check engine light off.. i'll post picture of my ride tomorrow.. I got it dropped finally!!!.. hey teamblurryCL.. got pictures of your ride? send me some or send me the link aight.. my e-mail is kits5254@hotmail.com
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
