Check engine light on
Old Nov 3, 2006 | 06:51 PM
darkeman's Avatar
Does anyone know the proper way of resetting the maintenence light on a 1997 Acura CL? I think you stick a key in the slot in the dashboard, but I'm not sure what else you need to do. Does it have to the the car's ignition key for it to work? Do you need to turn it? Do you have to press in and turn the engine on? Please help. The light is driving me crazy.
Old Nov 3, 2006 | 07:38 PM
CLean 3.0's Avatar
CLeanest in its CLass
the keyhole is for the maintenance square on the speedo. the check engine light you have to erase with a code scanner through the obd-II connector
Old Nov 3, 2006 | 08:27 PM
Sleep_DEPRIVED_Sleeper's Avatar
Turtle Charged, Biotcch!!
Go to the Autozone, borrow a scanner tool, remove the ash tray under the radio, plug the scanner tool in, turn the ignition ON, press READ on the tool, write down what the code is, then use the CLEAR CODE option on the tool to clear your CEL...
Old Nov 3, 2006 | 08:57 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Old Nov 5, 2006 | 09:18 PM
ItsDave's Avatar
Or fix the problem and reset the ECU
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
