changing brakes?
changing brakes?
im trying to change my brakes for the first time on a 97 3.0 and im not sure how to change em. i cant open the caliper. i think theres like 2 bolts in the back of em and ive seen my uncle do em b4 when it was his car but theres some kinda death grip on em. anyone know how to loosen them so i change em? am i doing anything wrong? all i got up to was taking out the tire and trying to loosen the bolts.
Re: changing brakes?
ok a trick i learned from a mechanic.. always keep pieces of pipe close by. its good to have one thats like 2 ft and one thats 3-1/2 feet. all u have to do is put it over the handle of the rachet and... viola you will have more "torque" to take off the bolt. it works everytime for me
you should only have to turn your rotors when they get warped. If you are warpping them, dont wash your car after you have been driving all day. Cold water, hot metal. BAD.....lay off the brakes a little bit. Or if you cant lay off the brakes get vented rotors.
Are you guys sure that you have to remove the mounting bolt for the Caliper? Most of the time that 'death grip' from the factory is there for a reason. Most new cars have easy release pins or brackets to change out pads.
I am not familiar with this cars system. If I am completely off base, let me know.
i got the freakin caliper out with wd-40 but the fuckin piston wont budge. i used a c clamp but even with the clamp its hard as hell. i bent the clamp itself. gotta go buy a new one, any easier way to push it back?
changing brakes-release pressure
i have a 99 cl rear brake pads need to be changed
how do i release piston on caliper, (push piston in) for clearance for new pads
I can remove old pads but I am having trouble opening wide enough to get thicker new pads on
PLEASE REPLY ASAP
URGENT URGENT URGENT
PLEASE REPLY ASAP
there should be a clip that holds the pads in and the caliper, and i think one nut i cant remember
but PM dustbuster4 he has detailed pics of a brake job i think
for new pads you need to take off teh caliper to get then in and lube them up
mada51589
Jan 9, 2025 04:40 PM
