CEL problem
CEL problem
po401,,recirculation of airflow
the CEL is on, when im driving every now and again the car loses all power and is acting if the key is only turned half way. the lights are on the key light is on. and about a second later its normal. what the hecks going on? im guessing i need a new cat but theres no funky smell or anything.
1998 CL 3.0
P0401 - EGR insufficient flow
Ignore the part about installing the thermoblock spacers and do this
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-thermoblok-spacers-install-egr-cleaning-615644/
If that doesn't do it try the EGR valve.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
There was a recall on the EGR, you should see if you qualify for it. Sounds like you need to clean or replace the EGR
SidhuSaaB
05-30-2020 12:40 AM
