CD Problems Continue
Old Aug 4, 2002 | 10:39 PM
finaI's Avatar
Okay, my car battery died, CD needs to have the code put in. Someone told me to look under my Ashtray to find the five number code to enter into the CD player. I found a code I guess to something under it, but it doesn't work with my CD player. How can I found out my code..? My car didn't come with the manual..which I am pissed about, but untill now there was no use of it.
Old Aug 4, 2002 | 10:50 PM
VeilSideCL's Avatar
aLL* sTaR
You could probably take it to an ACURA dealer and ask if they could help you with reseting the code. Drawback is they may charge you an arm an a leg
Old Aug 4, 2002 | 10:52 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
Here are some additional suggestions:
http://www.acura-cl.com/forums/showt...ght=radio+code
Good luck!
Old Aug 4, 2002 | 11:01 PM
gmb2000's Avatar
Open your glove compartment and look on the left side on the outside you should see 5 numbers
Old Aug 5, 2002 | 07:21 AM
finaI's Avatar
Problem Solved..Acura told me my CD player as me on "Lock Down." I need to pull out the Fuse for Radio Back-up, leave it out for twenty seconds, then to try the Code again. -Just an update for anyone who cares-
Old Aug 5, 2002 | 07:12 PM
VeilSideCL's Avatar
aLL* sTaR
Glad you solved your problem. I'll keep that info as future reference
Old Aug 5, 2002 | 07:57 PM
You would have gotten the same result when I recommended removing the negative battery cable.
http://www.acura-cl.com/forums/showt...threadid=76670
Glad you got it fixed.
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
