Car Heating Up!!!!!!!!!!!
Old Nov 14, 2005 | 09:24 AM
devildogUSMC's Avatar
I have a 97 CL 3.0 thats runs great while driving but a few seconds after i leave the car sitting at idle the temp. goes up like crazy. when i see the temp meter going up as the car gets hotter i give the engine some gas and the temp.goes down to normal. WTF!!!!!! help guys- Jay
Old Nov 14, 2005 | 09:25 AM
SwervinCL's Avatar
Nom Nom Nom Nom
your thermostat is not opening up. Change your thermostat.
Old Nov 14, 2005 | 09:29 AM
SwervinCL's Avatar
Nom Nom Nom Nom
It could also be your waterpump.
Old Nov 14, 2005 | 10:24 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Most likely the thermostat.
Old Nov 14, 2005 | 11:30 AM
ib_jimmy's Avatar
have u check to see if ur fan is working?
Old Nov 14, 2005 | 12:18 PM
hybridnrg's Avatar
...is now Carbon Fiber'd
I was having the same problems. First I noticed that my radiator had a small crack in it. So got a new one. But yet I was still heating up. Besides getting a new gasket on the thermostat, I took it to my electric mechanic I know and found out the motor was burned out, and that's why I was overheating. Got a Honda fan motor instead of Acura because Acura wants $350 just for a fan motor. But yeah fixed it and everything is better.
Old Nov 14, 2005 | 12:33 PM
mfkitson's Avatar
50? you must be kidding!
thermostat or water pump, probably thermostat
Semper Fi
Old Nov 14, 2005 | 01:39 PM
legendaryCL98's Avatar
'07 November = STI
thermostat
Old Nov 14, 2005 | 04:35 PM
SwervinCL's Avatar
Nom Nom Nom Nom
The only reason i was thinking it was the waterpump is beacuse if it is shot, then it would nt pump the coolent through the engine..
I would check the fans first. Turn your car on with the hood open and see if the fans come on or not. If not, its the fan.
Change the thermostat.
If that does not fix it, have the water pump looked at.
Old Nov 14, 2005 | 05:53 PM
SupraManAG's Avatar
One custom CL
thermostat
has happened to me on my fathers 3.2TL. Not that winter is coming you will also notice that you will have no heat from your a/c when idle.
Old Nov 14, 2005 | 07:42 PM
i'll try the thermostat first thanks guys - HOORAH
Old Nov 15, 2005 | 02:13 PM
oh one more thing. Is the thermostat housing connected to the upper or lower radiator hose in a 3.0 CL?
Old Nov 15, 2005 | 02:14 PM
SwervinCL's Avatar
Nom Nom Nom Nom
upper
Old Nov 15, 2005 | 02:30 PM
so then there are no bolts holding the thermostat housing in place?
Old Nov 15, 2005 | 02:36 PM
SwervinCL's Avatar
Nom Nom Nom Nom
2 bolts....
You have to drain the fluid first.
Old Nov 15, 2005 | 02:40 PM
If im looking at the motor from the front i see the upper radiator hose goping to the engine but there are no bolts where it connects to the engine just a hose clamp. however there is another hose connected to the bottom of the radiator that goes to the engine which would it be?
Old Nov 15, 2005 | 02:46 PM
Is it connected to this hose? or the hose below this one
Old Nov 15, 2005 | 03:16 PM
SwervinCL's Avatar
Nom Nom Nom Nom
Yes, its connected to that hose. You will see the hose clamp on the engine side. the engine clamp is connecting the hose to the housing that you want to remove.
Old Nov 16, 2005 | 10:51 AM
thanks
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
Bahamanurse1
Sep 10, 2015 10:05 PM
jordanboi
Sep 5, 2015 01:33 AM
dlknight
Sep 3, 2015 07:54 PM
