Car dies while driving???
Old Jan 24, 2007 | 12:33 PM
azmpire's Avatar
Hey guys,
So yesterday I'm pulling into work and my car just dies. Like all the needles drop and it cuts my power steering and power brakes. I was a little low on gas so I thought maybe that could be the reason. So after work I filled up and drove home without any problems. Then later in the day I'm driving to school at about 45 mph and it does it again. I barely pulled off the road without power brakes or steering. I'm afraid to drive the car because if it cuts out on the freeway I'll end up killing myself or someone else. I really need some help guys. What can be the problem?
Old Jan 24, 2007 | 12:50 PM
PimpCL23's Avatar
contrarian in fashion
i think Klepto has had some problems similar to this.
do u have any check engine lights on?
Old Jan 24, 2007 | 12:53 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Check your battery, make sure it has over a 12V charge, if it does, sounds like your alternator, that's what happened when mine died. Jump your car and drive it to your closest auto parts store or dealership, if you're scared to drive it there, have it towed, have them check your charging system, that's the most likely culprit if the car is just turning off
Old Jan 24, 2007 | 01:05 PM
PimpCL23's Avatar
check to see if ur headlights are extremely dim (not as bright as they should be). if its not as bright as before.. then ur alternator could be fuckin up or ur battery isnt holding its charge properly... in which case... ur car should be struggling to turn on if its a power issue
Old Jan 24, 2007 | 01:52 PM
azmpire's Avatar
The headlights look fine and the car turns on without any issues. I just let it run in the garage for 10 or 15 minutes and it didn't die. I think I'm still gonna drive it to autozone which isn't too far of a drive and have them check out the charging system.
Old Jan 24, 2007 | 03:31 PM
ajtcl's Avatar
Peace, Love & Acura
From the symptoms you've described, You should be looking to fuel system and electrical system. Check for CEL codes. then start running your systems. Check that your TPS, BARO, IMAP, EGR and VSS are all functioning. O2 sensors will not generally cause a stall. But any of the other subsystems can. Also, check that your car's imobilizer system is not malfunctioning and that all of your under-hood fuses are firmly in place.
Does the problem only occure when the car is warm. Under deceloration, while idling? Be as specific as possible and make note of what is happening just before your engine stalls.
Good luck.
If the car is not hard to start, then don't bother with the charging system. Move on to the others.
Old Jan 24, 2007 | 05:30 PM
azmpire's Avatar
I think its the ignition switch so i'm gonna have that replaced and see if it helps. drove it around all day today without issues. very strange.
Old Jan 25, 2007 | 10:44 AM
ajtcl's Avatar
Peace, Love & Acura
There is a recall on that. You should definately have that looked into. I didn't even think about that, but yes, that would certainly cause the problem you are having.
Old Jan 25, 2007 | 11:05 AM
(Mid-Atlantic)
didn't think about that either but it's a def possibility
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
jordanboi
Sep 5, 2015 01:33 AM
