Cant see needels !?!?
On right side of my gages I cant see needles anymore . I can see digits and left side fine only needles are look not lit up. What could it be lamp or fuse ? if lamp how can I find out which one or if its fuse where are fuses at ?
Can someone help me out ???
A-CL Post Whore w/N2O
Keep in mind that the needles themselves are not lit up (at least, not on the '97 model). My guess is that a light(s) has burned out (either a backlight, or the one that shines from the top of the gauge cluster).
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
acura-cl.com OG
Dust is correct, the needles on all the first gens don't light up. OK, if it serves me correctly, it is only a bulb. You have 2 bulbs that each light up half of the cluster, or the 2 needles in question. If you were to take your cluster out, there are 4 wedge bulbs in the rear, and two very small wedge style bulbs on top. These bulbs take care of illuminating the needles. You could do it your self, but you have to get your hands on those bulbs first, they are hard to find.
acura-cl.com OG
Autozone might have them. I know you cannot get that bulb in colors, alot of people want to replace them when custom gauge work is done but cannot find the bulb. But if all you are looking for is a plain bulb you might be able to find them. A dealer could def get you one, and it is an easy install one you have the bulbs. Only like 6 or 8 screws, and your done.
u pull the cruise control button and the dimmer switch out and there are 2 screws...under the top of the guage is 2 more screws. the cover should come right off. i think about 6 more screws holding the guage itself down....unscrew that and pull that sucker out. i think u can find those bulbs at Radio Shack...i wanna replace mine with some bright LED.
