camber kit or not
6th Gear
camber kit or not
im confused i have read that any drop of 2in or more requires a camber kit but at the same time i have also read that 1.75 in requires a camber kit but it is less than a 2 in drop i am getting intrax springs or the neuspeed which are 1.75in so i need to know whether or not i need a camber kit.
please respond with any info
bayne9830cl
bayne9830cl
Fawkin Gruvin
i think that it just depends on how much you drop your ride not the actuall kit that you used to lower it ? the lower you go then the more you are likely to need a camber kit!
Comrade Stalin
Originally posted by rad_cl_racer
hey i have a nuspeed drop of 2 and my front tires are telling me that i need a camber kit!! sux but the car looks great
I put neuspeed sports) 1.75/1.5 F/R) and the alignment in the front was ok, but the rear was off by 2 degrees so they said i needed a camber kit for the rears only. what do you guys think?
A-CL Post Whore w/N2O
Originally posted by lomeli3.0CL
i got mine on a pro kit... only 1.5 all around.. but i heard that you will need a camber kit for anything else other than a pro kit...
http://www.acura-cl.com/forums/showt...kit+camber+kit
I just did the neuspeed / kyb setup. AlInMeNt PrObLeMs!!! without the camber kits front and back. Definitely worth getting the camber kit. I have a friend that didnt get the camber kit and the inside of his tires wore down BiG TyMe!!!
Insert Sarcasm Here
It varies by the car I think. I have the pro-kit and have no camber problems. Some with those springs need the kit and some don't. Just get it done and pay attention to the tire wear. You can catch it early enough to tell you need the kit and not ruin the tires. Just keep an eye on them.
Atl/Mia reppin'
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
