Cam Gears
Old May 1, 2008 | 08:51 PM
DaInFaMMuS1's Avatar
Cam Gears
I was just wondering, what kind of gains can be had from using an aftermarket cam gear/gears in your vehicle? Are the retardation and advance in timing with the aftermarket cam gears something that you wouldn't be able to accomplish w/a stock one/set?
Old May 1, 2008 | 08:56 PM
AznX TL's Avatar
where is....
i've always thought of cam gears as an "accessory" mods, to go along with a built engine to actually make a difference.
Old May 1, 2008 | 10:53 PM
972.2's Avatar
from what ive heard cam gears only give significant horsepower on turbo applications.
Old May 1, 2008 | 11:07 PM
G22_Powered_YA1's Avatar
well it gives a little bit of power just being lighter than the stock one, as a first. . . the retard/advance is somehting you can NOT do on a stock gear, a single cam application though the advance/retard only moves the torque curve up or down, nothing more, you cant go into the real technical stuff like overlap and all that shit like you can on a twin cam motor
Old May 1, 2008 | 11:12 PM
suremang's Avatar
almost done...
eh i wouldn do it. id only do it if i minimally had an aftermarket camshaft but those dont exist for our cars.
Old May 1, 2008 | 11:25 PM
i'm sure there are aftermarket camshafts available for the F series motor.
G22, In DOHC applications, what advancements can be seen w/them in retard/advance w/o aftermarket camshafts and with them, do you know?
Old May 1, 2008 | 11:36 PM
with the twin cams you can get into whats called overlap, where you start avancing the intake cam while retarding the exhaust cam, or vice versa, stuff like that can yield varied results, very flexible depending on what sort of application youve got, eg. FI vs N/A. . . that all can be done on stock cams, the only difference between the stock cam and the aftermarket ones are lift, and sometimes duration. . . but all that can be worked around if youve got an adjustable gear this sort of tuning should ALWAYS be done on a dyno by a professional though
there are aftermarket cams for F applications, Bisimoto makes them and a place called F22parts.com or something like that
Old May 1, 2008 | 11:51 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
The retardation is strong in this thread
Old May 2, 2008 | 12:09 AM
maybe it is, its been a while since Ive talked about cams and shit
Old May 2, 2008 | 12:21 AM
972.2's Avatar
ive only seen one cam for an f22b1. dont remember where, it was some site that like hand machines parts for the motor. i think it was $1200. ridiculous.
Old May 2, 2008 | 01:32 AM
starboy2nv's Avatar
First EVER K24 Turbo CL
ROFL
Old May 2, 2008 | 10:45 AM
Yeah Bisimoto is a company that makes cams for the F series. I dont think they cost anywhere near 1200 though, the prices that i've seen were similar to skunk2 and JUN at around 500-600.
As for the "retardation being strong" in this thread, this is something i know very little about so i was trying to get some info
Old May 2, 2008 | 10:55 AM
Here's what my friend Marc told me:
"Adjustable camgears are used in adjusting cam timing (retards or advance). They can have an huge effect on your fuel curve, which in turn yields to more power. However tuning would be necessary. Also should mention it changes valve overlap which induces a change in where your motor makes its power."
guess if i buy em i should be making an appointment with the a tuner lol.
Old May 2, 2008 | 11:09 AM
starboy2nv's Avatar
well... allow me to chime in youngin'
You have a intake. You have a full custom exhaust. Get the cam gear(s). Tune it.
And then we go for a ride. lol
Old May 2, 2008 | 03:22 PM
lol. just trying to make sure it's money well spent. When r u gonna decide what you're doing w/ur car?
Old May 3, 2008 | 01:15 AM
starboy2nv's Avatar
already did homie
Old May 3, 2008 | 10:16 AM
shineynitelite's Avatar
NAWWWWSSSSSS
this thread receives my stamp of containing no correct information!
Old May 3, 2008 | 10:58 AM
then by all means, correct it
Old May 3, 2008 | 01:46 PM
PLEASE do
Old May 3, 2008 | 10:44 PM
tron's Avatar
you can get a reground cam from f22parts.com I think its like $300.00
Old May 4, 2008 | 10:18 PM
NAWWWWSSSSSS
you dont need a tune, with a sohc your basically moving the powerband, i retarded mine 2 degrees and found a much more useful powerband. it has nothing to do with your fuel curve. etc
Old May 5, 2008 | 04:05 AM
thus I said torque curve, never mentioned fuel
Old May 5, 2008 | 11:15 AM
NAWWWWSSSSSS
whatever makes you feel better, but i wasnt even talking to you.
Old May 5, 2008 | 12:46 PM
Makes sense. Just got me some Golden Eagle product so we'll see how it works out. Hopefully it's worth it lol.
Old May 5, 2008 | 01:29 PM
starboy2nv's Avatar
while your on a shopping spree chris, wanna buy me something cool?
Old May 5, 2008 | 05:09 PM
just a last ditch effort to save my limited inteligence
Old May 5, 2008 | 05:32 PM
lol G22 you did fine, thanks for the helpful info bro , well at least i thought it was helpful
Old May 6, 2008 | 06:13 PM
teh CL's Avatar
what's that i see in your avatar? H23A? ....explain
Old May 7, 2008 | 12:09 AM
Ummm...thats nothing, just an avatar... for now
Old May 9, 2008 | 05:39 PM
teh CL's Avatar
oh yeah....
interesting...
Old May 9, 2008 | 07:40 PM
lol I pm'ed u Allan.
Old May 9, 2008 | 11:26 PM
CH46ESeaKnight's Avatar
Your lift and duration CAN NOT be changed with adjustable gears.
There is a lot more than just Lift and duration in camshafts. In regaurds to aftermarket and stock.
Lift, Duration, Advertised Duration, Lobe Seperation, Ramp Rate, and some more. There are so many different combos, you can't even imagine.
The only thing adjustable with the cam gears is the TQ curve. Move it up in the RPM range or move it down. (Except DOHC while yes you can change overlap, but not lift and duration)
And yes some turbo applications will benifit more than a NA motor from retarding the exhaust cam (In a DOHC) a few degrees. The gains can be substantial.
Not bagging on ya, just a little FYI!
Old May 9, 2008 | 11:46 PM
I'm no pro on the Acura motors, but is there not a Crankshaft to Camshaft sensor problem to deal with, when you say no tune needed when retarding cams?
Like I said no pro on the Acura, but I know in my Tahoe 350 motor, I put in a new cam and degreed it back 4 degrees. It did need a new tune, not just for that, cause I changed all kinds of shit, but the crank to cam sensor had to be delt with in the tune.
Old May 10, 2008 | 12:33 AM
yeah I know, I did say stock vs aftermarket CAMs
Old May 10, 2008 | 12:43 AM
"""""the only difference between the stock cam and the aftermarket ones are lift, and sometimes duration""""""""
Thats what you said, and it is not correct. Re read the post.
Old May 10, 2008 | 08:37 AM
I was refering to your 1st sentence. . .
Old May 10, 2008 | 10:54 AM
NAWWWWSSSSSS
well every car is different, hondas do not need a tune tho. couldnt tell you more as to why.
Old May 10, 2008 | 01:18 PM
You mean this sentence, my first one.
""""""""(ME) Your lift and duration CAN NOT be changed with adjustable gears.""""""""
Well you said, """"""""""""that all can be done on stock cams, the only difference between the stock cam and the aftermarket ones are lift, and sometimes duration. . . but all that can be worked around if youve got an adjustable gear this sort of tuning should ALWAYS be done on a dyno by a professional though""""""""""""
No You can't work around Lift and Duration with adj. gears.
Everything you said in your entire post is incorrect, except that you can adjust overlap with twin cams and adj. gears. Other than that everthing else is wrong.
Like I said, i'm not trying to be an ass, but you giving totally false info here that might give someone the wrong idea, and cost them some doe!
Old May 10, 2008 | 04:02 PM
so you can't adjust lift and duration, but only overlap and powerband?
Old May 10, 2008 | 04:40 PM
Correct! Lift and duration is decided when the camshaft is cut. No adjustment in the world will give you that. If you want to change lift or duration you have to have your cam recround, or get a new one.
Overlap on twin cam setup only. A single cam you can not change overlap. If you retard the cam on a single setup you are doing both intake and exhaust.
All you are doing when you adjust the cam, is changing when and where the valves open in relation to where the piston is in its stroke.
