Bulbs??
Old Jun 12, 2004 | 02:11 AM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
Bulbs??
What bulb is needed for the turn signals?
i mean the bigger bulbs not the side on where if u unlock the car it flashes
also who here has wired the turn signals so that they run all the time and also used as a turn signal?
instructions as well?
thanks
-joe
Old Jun 12, 2004 | 06:25 AM
97Black2.2CL's Avatar
got audio?
I think its the 3497/1156.. the single filament one. i didn't wire it though..
Old Jun 12, 2004 | 12:39 PM
creationCL's Avatar
CLanty-eyed
7443 for your year car.
Old Jun 12, 2004 | 12:45 PM
99CL's Avatar
blah blah blah
I have mine on all the time. I just drill and hole and put in another bulb. U could get a double filment bulb and socket, that will work too. I believe the integ are double, so just go to the junk yard...
Old Jun 12, 2004 | 09:22 PM
athlonxp's Avatar
Okay basically I got this socket from Advance, cheap but works.
It holds a 1157 bulb. It's $3.49 a socket. Okay this does require a little work though.
The two wires coming from this are both positive, the body is the ground, so to make it work I had to solder about a foot of wire onto the body.
So now I would have 3 wires, two positive and one negative. You now basically splice one of the positive wires and the ground wire to the wires of the factory socket.
The next wire you would have to splice into the positive wire of the factory corner bulb of the same lens. The little 194/168 bulb. And there you go. Whenever you turn on the parking lamps the whole bumper lens will illuminate, and when you use your signal you turn on the second filament in the bulb and there you have it a double function bumper lens.
Hope this helps. I don't know if if the integra sockets are a direct fit but if they are they'd be the better choice for a cleaner install, but I know they don't come cheap and I know they aren't readily available. So you have this route here to go.
And in splicing I mean using these here:
Quick Splice Connectors
Good Luck,
James
Old Jun 12, 2004 | 09:26 PM
athlonxp's Avatar
It'd actually be the 7440 bulb, the 7443 is for the integra, that's the dual filament bulb.
Just setting facts straight, not trying to be an ass.
-James
Old Jun 13, 2004 | 01:25 AM
thaks for the info but cant i just split the wire from the turn signal and hook it up to the running lights too? like have an extra wire runnign to the running lights and also still have it hooked up to the normal wuire but just split it, i dont want to mess around with it too much but would like the constant running lights like a teg
hashbrown
Feb 18, 2022 11:20 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
h22lude
Sep 27, 2015 06:22 PM
ripit
Sep 26, 2015 06:19 PM
eastcoastguy
Sep 23, 2015 06:29 AM
